Front end swap
  • Spootinay
    • Jul 2011
    • 62
    • NE FL
    Front end swap
    Hey guys, I am swapping the front ends of the 79xs11sf and the 79xs11f. The standard I have completely torn down and refurbished, the special is in rough shape. The front end of the standard is in rough shape compared to the special, hence the swap. everything is working out great except the differences in wiring connections.
    Basically I need the wiring diagrams for the two bikes. Anybody have them?
  • jwhughes3
    • 2798
    • Home of the Alamo
    Special to standard is ok
    Standard to special is dicey.
    Unless you are taking the whole triple tree. Its swapping the standard forks into the special tree that quickens the steering and is discussed as "twitchy" due to a loss of proper trail.
    My standard has special forks and does fine.
    John
    '81 XS1100H - "Enterprise"
      Originally posted by Spootinay
      ...Basically I need the wiring diagrams for the two bikes. Anybody have them?
      The wiring color codes (and number of wires) are identical between the two bikes, so match color to color. I assume you're planning on using the special gauges. You'll have to reconfigure the harness plugs to accept the gauges, the handlebar controls should be the same. You'll lose the fuel light unless you install the special sending unit into the standard tank.
      And you don't even need to cut the wires; if you disengage the connectors in the plugs you can pull them out then reinsert them into the correct plug.
      • jwhughes3
        • 2798
        • Home of the Alamo
        Fuel light
        I swapped sending units when putting the Venturer tank on my 80 Special and light works as Steve said...I will likely swap units back when I swap guages for Standard and fuel gauge.
        John
          Hi John,
          either fork swap works just fine and retains the stock trail as long as you swap them fender, triple trees and all.
          But you got the fork/tree mix backwards.
          Special fork legs in Standard 'trees moves the wheel forward to reduce the trail and make the steering lighter.
          Standard fork legs in Special 'trees moves the wheel backwards to increase the trail and make the steering heavier.
            Hi John,
            And neither 'mixed' combo is a good thing... unless you have a trike or sidehack, eh Fred?
              • 8700
              I've run the Special leading axle forks in the standard trees before, It looks a little more raked ↓ but gets real funky at 75MPH.
              Here's with FJ forks and trees, just the opposite ↓
              • DCracer25
                • Jul 2011
                • 179
                • harpursville NY
                Ok can you tell me the difference between the forks? I am building a trike out of a 81 xs1100 standard venture. if I swaped special forks into my standard would I have to use the brake caliper and front wheel from a special?
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  • Fort Myers, Florida
                  Dont think the wheel makes a difference, but the offset is different so the brakes and finder are different, you need to use the correct offset stuff if you change
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                    Ok can you tell me the difference between the forks? I am building a trike out of a 81 xs1100 standard venture. if I swapped
                    In your case, a swap to special forks with standard trees would make sense, as that will reduce steering effort (which can be quite 'heavy' with 'normal' forks). The handling problems associated with too little trail aren't a problem on a trike or sidecar unless you go to negative trail.
                    What do you have to swap besides the forks? Well, the wheel/brake rotors and axle are the same, but that's it. You'll need the special calipers, fender, and speedo drive/cable also. The calipers are completely different from the standards, and a bit funky...
                    • DCracer25
                      • Jul 2011
                      • 179
                      • harpursville NY
                      alright thanks for the info, Now does anyone have a set of special forks, calipers.fender, and speedo gear and cable? for sale or trade for the standard forks and stuff.
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        Here are the forks, I am sure you can ask him about the rest, might make a deal on all
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                        • DCracer25
                          • Jul 2011
                          • 179
                          • harpursville NY
                          Thank you again, I emailed him on the forks and calipers and stuff so we will see what happens. Can someone please explain the difference between the forks? Is it the length? I am just curious to know.
                            ...Can someone please explain the difference between the forks? Is it the length? I am just curious to know.
                            The Special forks were a styling thing; while built differently, they primarily were to give the illusion that the bike had a 'raked' front end like a chopper, but the as-mounted geometry is the same as the standards. Yes, they are longer, but the front axle is mounted on the front of the forks instead of the bottom, so 'effective' length is the same. The triple trees have less offset to compensate for the leading axle. The brakes are a weird 'pivoting'-mount setup, being held onto the forks with a single long bolt that the calipers rotate on to allow pad wear. The pads are angle-cut for this reason, and come as left and right sets. No parts will interchange between the two types other than what's been noted.
                            • DCracer25
                              • Jul 2011
                              • 179
                              • harpursville NY
                              Now I understand the difference, thankyou again for the help, as usual this forum has been a big help to me as I am rebuilding the bike into a trike for my wife. I have also learned a great deal from everyone who has helped me. So if I can help anyone I will do itin a heart beat, this forum is the best. thanks again Dennis
