Ok seeing how I have no manual or can I currently afford one. What is the best way to get the carbs off to clean them and. Once clean I was told id have to resync I don't know if this is true but help me out guys I know y'all know your stuff
carb question
I searched carb cleaning
See Kat's post:
Go to member list for Catatonic Bug. He has a downloadable manual in his signature.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold" -
Hi John,
what JW said. OK, IF your carbs were perfectly synched before you took them off for cleaning and IF you managed to not move the between carbs adjusting screws and IF you carefully returned the slow running needles to their former positions IN THEORY you wouldn't need to resynch after cleaning.
Otherwise, resynch after cleaning and perhaps resynch again at every oil change.Fred Hill, S'toon
"The Flying Pumpkin"Comment
Removing
As far as removing the carbs goes, if you have the OEM air box it is a bit of a challange. The manual download will cover most steps, follow them in order. A tip that I have found that helps is unhook the throttle cable when the carbs are half way out, much easer to get to then, same with install, hook it up when half way in, good luck, and be sure and remove the emulsion tubes, dont just spray cleaner in there, also dont soak the bodies in carb clearner, it will damage the throttle seals
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
unhook the throttle cable when the carbs are half way out, much easer to get to then, same with install, hook it up when half way in, good luck//////////////WAY too much over thinking going on here IMO. Twist throttle grip WO........lift cable out of retainer on valve cover while releasing throttle......painless. Lift up on cable and housing manually to rotate throttle shaft..........lightly wedge a screwdriver behind shaft assembly or hold open by hand flipping cable end out of retainer............reverse for install.............totally painless.....81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Yea
Yea, those 4 or 5 steps sound easer then slide out carbs, unhook throttle cable where you can just grab it with your fingers
unhook the throttle cable when the carbs are half way out, much easer to get to then, same with install, hook it up when half way in, good luck//////////////WAY too much over thinking going on here IMO. Twist throttle grip WO........lift cable out of retainer on valve cover while releasing throttle......painless. Lift up on cable and housing manually to rotate throttle shaft..........lightly wedge a screwdriver behind shaft assembly or hold open by hand flipping cable end out of retainer............reverse for install.............totally painless.....1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
pay real close attention to how you pull them out because getting them back in can be really frustrating1980 xs1100sgComment
