Front brake wobble
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Front brake wobble
    I have a front brake wobble under hard brakeing. Someone on here told me to check the rotor retaining bolts, and yes, one is slightly bent He said to just replace them with new from a hardware store. I don't want to take chances with my brakes Anyone know if I need "special" bolts for my Special
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    There's nothing 'special' about that bolt as far as strength goes. Any better 'graded' bolt will work...
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      Thanks
      Thanks CS, didn't know if it would be worth the time to track down a grade 8 or some such.
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
      • Danny Crawdad
        • May 2011
        • 239
        • Birmingham, Alabama
        I had the same problem, and did end up throwing a grade 8 in there, but only because that's what they had at the parts store . Cost about $2, I think. Also probably overkill for the load put on those bolts!
        I just took the old one in and they let me go in the back and match it up. It was either Advance Auto or AutoZone, one of the larger chains. I'm sure you can find it at any bolt-selling-retailer
        XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
        Well, goodness. Look what we've got here.
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          Two$
          Two $, at that price I will get them, I haven't looked and didn't know that grade 8 would be that easy to find in metric / size. Thanks
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
            Good choice on the grade8 bolt. Any pieces attached relating to suspension, braking or steering uses grade8 fasteners. That includes attached bumpers on cages. For safety reasons, that is DOT regulations. A good thing to remember if in question as to what grade of fastener to use depending on its location.
              Originally posted by motoman
              ..Any pieces attached relating to suspension, braking or steering uses grade 8 fasteners..
              That's not neccesarily true.... most will be grade 8, but not all. One thing the off-roaders have found out is the grade 8 bolts won't take the shock loads and they break, while a grade 5 will deform before breaking. I do remember from my mechanic days that most shock hardware was grade 5 for just that reason. The fact that the OEM bolt will bend tells me that it wasn't any better than grade 5 to start with...
                +1, The higher the grade the more likely it is that the fastener with snap rather than bend. But I replaced my rotor bolts with stainless bolts so I am screwed anyways.
                • Laptop_geek
                  • Nov 2011
                  • 135
                  • Memphis, TENN.
                  I found that Lowe's has a good selection of metric sized bolts.
                  1979 XS1100
                    Watch your grades!
                    Hi Guys,
                    SAE Grade 5 is best for fasteners that need toughness ahead of high strength, SAE Grade 8 has a higher tensile strength but it'll snap before it bends. Note that SAE grades only apply to inch-sized fasteners.
                    The Metric equivalent to SAE Grade 5 is Grade 8.8 and it's plainly marked on the bolt head.
