Carb adjustment: new air filters and exhaust
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Carbs
    The carb rebuild is not hard to do yourself. Just follow the guild on here and take your time and dont skip "ANY" of the steps, remove and clean the emulsion tubes! If you are changing the "C" clip hight on the needle, get some good snap ring pliers $11.00 at Mikes http://www.mikesxs.net/products-7.html And invest in a real good set of screwdrivers if you don't have one, a perfect fit for the different sizes's is great, and soak your jets with penitrating oil if they don't come out easy. Good luck with your bike and keep us updated
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • Danny Crawdad
      • May 2011
      • 239
      • Birmingham, Alabama
      I have pods and a 4->1 and a proper re-jet + tune, and it was worth every penny. I did not feel any noticeable loss in low-end grunt, and have more mid-range power. No rideability or reliability issues at all. It rides just fine in low-speed low-RPM rush hour traffic, and flies when I have open road. If I had to do over again, I absolutely would, in a heartbeat.
      XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
      Well, goodness. Look what we've got here.
      • TADracer
        • 1417
        • Kenner, Louisiana USA
        As you can see you are getting both sides or the arguement. There is alot to be said for leaving it all stock because this is the best compromise for a street ridden machine where you want excellent performance with drivability (perhaps that should be rideability). On the other side some mods CAN give you better performance and with alot of tuning you CAN gain back the rideability too. Its a matter of how much work you want to do (and keep doing) at every tuneup.
        What I can tell you from experience is that you will have to go alot farther than just a carb adjustment to get it right.
        I direct you to the statement under my signature.
        Mike Giroir
        79 XS-1100 Special
        • Danny Crawdad
          • May 2011
          • 239
          I think it really all comes down to the tuning -- my brother in law has a bike shop and has worked on old metric bikes for 30+ years. He had the carb broken down, cleaned, rebuilt, jetted, on the bike, and tuned in around an hour. I asked him last night if it was a "nightmare" to tune, and he laughed at me.
          However, I probably couldn't have done it nearly as easily on my own. He had the tools and experience to make it look simple.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Dyno
            The only way to realy tell your power gains (without a Dyno) is to take her to the track. If you turn in the mid to low 11's, you have improved on the stock tune, if not, you haven't, or, you can't ride Either way, if the changes put an even bigger smile on your face when rideing, it is worth it
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
            • Danny Crawdad
              • May 2011
              • 239
              Well, like you said, even a track is not a good way to test the tune unless you have done multiple passes and can make nearly consistent runs. I can't .
              I don't know if any power has actually been *added*, but I can tell a shift in the power band from OEM. I don't spend a lot of time below 3k on this bike unless I am starting off from a stop, and I haven't noticed any difference there. Maybe my driving style is different, but I usually cruise at around 4k
              What I'm getting at is that modding the intake/exhaust/jetting isn't sounding the death knell for your bike. It isn't going to turn it into some unreliable wreck -- mine runs as well or better than ever, and in the thousands of miles I've put on it since the change, I haven't had a single issue with the carbs aside from when I had some dirty gas.
              But don't hack up the stock pipes, OP, do what I did and stick them in the attic for later
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                Oem
                Not picking on you Danny, that is why I didn't use "quoat" in my last post. I think most of these bikes have some, if not many mod's, especialy exaust, as that is the 1st thing to go, due to rust or ease of replacing. My thought is only about preformance, you won't gain much without big $$$$ IMHO. If someone wants more sound, cool look or just something different, I say, what ever makes them smile is what they should do, it is their bike
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                • Danny Crawdad
                  • May 2011
                  • 239
                  Oh, I know! Just thinking out loud myself. And I can take some picking on, too . I probably deserve it a lot of the time, just ask my wife.
                  But I agree 100% about not getting big performance gains without big $$$. Pods, jets, and exhaust aren't going to transform the machine into something it ain't! Any HP gains are going to be pretty negligible, but it can tweak when the power is delivered.
                  I honestly wish I could get less sound... I'm thinking about sticking a DB Killer or re-packing the exhaust on mine. Quiet is good, in my opinion.
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    Pipes
                    I am with you on that. One of the MANY things I love about my stock exaust is not telling every Johnnie Law man where I am and what I am doing But, they have to catch me 1st
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • cywelchjr
                      XS-XJ Super Guru(Deceased)
                      • 4450
                      • Sacramento, CA
                      Remember that the OP is talking about OPEN pipes. A good 4-1 can indeed be tuned to perform well with only a small loss down low and a good increase in the mid to high range. But if you get rid of all the back pressure, the system becomes just about impossible if not impossible to tune, as these bikes do need SOME back pressure. Most of the professionally made systems for these bikes were tuned to provide enough back pressure to keep the system happy, but when you start playing with things and go with straight pipes, this is when it can become impossible to get a bike that's got decent manners on the street.
                      • Danny Crawdad
                        • May 2011
                        • 239
                        Whoa, I somehow missed that -- you are absolutely right about that. Same is true in most non-turbo vehicles, too. Open pipes sound like crap and perform like crap due to loss of exhaust velocity.
                        • cywelchjr
                          • 4450
                          • Sacramento, CA
                          Yep, he says right in there he wants to go to pods and take out the baffles. The pods aren't really much of a problem, you can easily tune around them, and an aftermarket exhaust (even with pods) the same, but pull the baffles even if you leave the stock airbox in place, let alone with pods, and the bike becomes almost impossible to get tuned for even performance.
                          • petejw
                            • 2269
                            • sydney australia
                            leave the exhaust,
                            stick the pods on,
                            bump the jets up 2 sizes
                            and ur good to go.
                            pete
                            new owner of
                            08 gen2 hayabusa
                            former owner
                            1981 xs1100 RH (aus) (5N5)
                            zrx carbs
                            18mm float height
                            145 main jets
                            38 pilots
