Rear Shock Adjustment Sans Spanning Wrench
  • buickyouth
    • Apr 2004
    • 202
    • Chicago, IL
    The manual calls for a spanning wrench from the toolkit to facilitate the adjustment of the rear shocks.
    I don't have one of these.
    Has anyone got a good workaround to be able to adjust them without the tool?
    Thanks,
    Ian
    I am a rhinoceros and my skin is three feet thick.
    //////////////WARSENAULT/////////////
    I use a large pair of Channel Locks and a rag (to protect the finish).
      Yep, that's the best way. Most XS rear shocks I've seen have a hole in the adjuster that you're supposed to insert the spark plug wrench handle into to adjust. But this usually results in breaking off the piece welded to the adjuster, so I don't recommend that....
      That 'spanner wrench' didn't come with the bike...
        I've often wondered about that...
        The "correct" tool looks something like this, but generally only single-sided:
          Yeah, the owners manual mentions it, but that was an 'accessory' you had to buy separately. I'm not so sure you could have got into the pouch/toolbox anyway, as it is a very tight squeeze with the other tools, particularly if you own a standard and were trying to get the cable in there too....
          Which is no doubt why the cables were the first to get lost...
          • buickyouth
            • Apr 2004
            • 202
            • Chicago, IL
            Thanks guys.
            Do I need to remove the rear wheel to make these adjustments or can I get away with center standing, gripping and twisting?
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              I did mine on the centerstand. If those things are a bit rusty, I'd sugest some PB Blaster or WD40. Maybe backing off one notch then going back to original then tighter if that's the way you're going. (let the spring pressure work for you to loosen things up a bit before you go tighter)
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
                I used to adjust mine with channel locks wrapping a heavy rag around the lower portion of shock so it would'nt scun thingsd up too bad............now, all these years later got the CORRECT adjuster. It was offered as a Yamaha accessory, and no it won't fit in the tool box. Mine is still in the original bag with pics and instructions. The one like showed in the above thread may or may not work, depends on the curvature. The OEM one has an arm attached that swings and has a round stub on the end to fit the the round recess. Works perfect, just wish I knew it was available back in the day. On occassion one can be had on the Bay, usually under NOS parts.
                  • 8077
                  The spanner is available from Mike's XS. It fits the stock shocks, and Progressive shocks, Hagons, and I'm sure, several others.
                  • Eveready1100
                    • 539
                    Have you got a photo, Motoman?
                    • GLoweVA
                      • Jun 2011
                      • 1957
                      Here's the link to mikeXS' wrench: http://www.mikesxs.net/search.html?q=Shock+Ring+Wrench
                      The Green Monster
                      Got him in '04.
                      Scarlet
                      Got her in '11
                      Hugo
                      Cold weather ride
                        Eveready, see if I can't get a pic up for ya later.
