Valve cover gasket 80G
  • webbcraft2150
    • Sep 2002
    • 1605
    • AUSTIN.TX
    Parts-n-More been out of them for two weeks. Bike Bandit want $40+. E-bay is a no show. Old Bike barn dosen't list them. Not a fan of just using Yamabond or RTV as the sole sealer. "bout ready to go the dealer
    I get my dealer stuff here:
    Yamaha Sportscenter
    From them, the gasket is $26.33. That's a fortune, but it sure beats the $39.57 retail price!
    Marty (in Bangor, ME)
      Yamabond works great.... I don't need no steenkin' gaskets...
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        • Fort Myers, Florida
        Gasket
        I ordered one from this guy for my 79, you have to ask him for the one you need, think he cuts them as needed, $16.00 + S/H
        http://www.ebay.com/itm/Yamaha-XS-11...sories&vxp=mtr
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          If your going to do that, just get the material from your local auto parts store and print it out from the templates available from the UK site. A lot cheaper and probably a LOT faster as well, since you can buy that material in the matter of a couple hours at the most in most cases.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Laser cut
            That would work also, but precise laser cut is nice and a piece of gasket materal that big woulg probably cost about the same. He also has a great price on two sets of bowl gaskets (8 total, always good to have around) iam just trying to help save a few $$$, if he "IS" going to order them, these are just as good as OEM and he ships USPS Priority, got mine in two days they are cut perfectly and he will combine shipping
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
            • earl G
              • Aug 2007
              • 468
              • allentown,pa
              got one from cycle-re-cycle part 2. paid $10.95 plus shipping
              80 xs1100G
                Steve, what # Yamabond would you use for that valve cover gasket? I gotta do mine pretty soon.
                  That's who I always use earl.
                  That's pretty much the only place I'll buy a gasket for. For some reason I can't get the Threebond 1194 to seal on the valve cover.
                  • petejw
                    • 2269
                    • sydney australia
                    +1 on what steve said,
                    if u havent got yamabond,
                    just use silastic.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    1981 xs1100 RH (aus) (5N5)
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                    • XS1100_OEM4ME
                      • Mar 2009
                      • 1619
                      Seal
                      The gasket I bought on Ebay seals with no gasket sealer at all (except for a little around the cam plugs) I put all the bolts in finger snug, starting from the middle of the cover, then working out to both ends at the same pattern (two left bolts the two right bolts, till all the way to the ends) Next I tighten them down in the same order, starting with the middle bolts 1st, not even a seap
                      1980 XS1100 Special
                      1990 V Max
                      1982 KZ750 LTD Twin
                      1974 CB750-Four
                      Past/pres Car's
                        Yup, that's why I order the $11 gasket and keep a couple extra around. The Threebond works great everywhere else but I always end up with a leak on the valve cover when I use it there.
                        Others have said it works for them also but I've seen a lot of leaky ones. Especially on longer trips.
                          Phil, I'm using the Yamabond 4. Absolutely great stuff, I used that to seal just about everything on the SG I did and didn't have a single leak. It's a bit runny, so don't apply too much, and I wouldn't try it on anything but a machined surface. I love it....
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            confused
                            Is ten bucks $$$ for a gasket That is a "baconator combo" at Wendy's Is it the two or three days to get it, or, just a love for "walking on the wild side" and hoping it don't leak
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                              I think the trick for using Yamabond as a gasket is to apply it to the cylinder head and not the valve cover. A bit more difficult but less chance of messing up the bead and causing a breach that way. Thanks Steve, I'll try the #4.
                              If the valve cover only had an o-ring gasket...
