New leak!
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    New leak!
    After rebuilding my front master cyl twice, I found a new leak (or the one I thought was the plunger leak) It is leaking between the white / clearish resiervoir tank and the unit base (the part with the plunger and mirror on / in them) I didn't remove this part from the base when I rebuilt it, I have checked all the screws and they are tight, it just seaps out overnight an is damp with brake fluid from seam to the bottom of the base It is nice to have a brake fluid leak just above the freshly painted tank Is the a (availble) seal between those parts? and can I take apart to fix without breaking it for good
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    That's not a untypical problem...
    The reservoir comes off (after draining and removing all screws) by twisting/gently prying until it pops off. The o-ring seal isn't available from Yamaha (never was either...), so you'll have to try to match it at the parts store. Or you could just thoroughly clean/dry the joint and put some silicon sealer between the plastic and the aluminum body. That's worked for me...
      Does anybody here have the specs on that packing? I'd like to keep some handy. I have two that are leakers as well.
      Marty (in Bangor, ME)
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Thanks
        Thanks again Steve You are a big help as always I have a "high torque" permatex gray RTV, Ill give that a try
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
        • Lamric
          XStremely XSive(Deceased)
          • 410
          • Kenley, Surrey, England
          Does anybody here have the specs on that packing? I'd like to keep some handy....
          Best info I could find on that o-ring was this - at least it narrows down to a choice of two sizes
          Brian
          XS1100 LG "Mr T", SG "ICBM" & FJ1200
          Check out the XS Part Number Finder
          Be not stingy in what costs nothing as courtesy, counsel and countenance.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Wow!
            WOW! Was there ever 30+ years of crud in there The "O" ring was the best part, looked perfect after cleaning. It looks like it had some kind of sealer that had hardend an crystelized. Cleaned it out with a small flat head screwdriver, then cleaned the alum housing with a flat head exacto blade (all kinds of crud clinging to it also) Put a small bead of RTV in both groves and around the round plastic O ring holder, put her back togather with a new cover and cover gasket. Going to let it set over night before I reinstall, thanks,
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
