Wiring question
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Wiring question
    Does anyone know where to get the plastic sleeving that the harnesses use?
    I've got a splice repair on my handle bar switch and the PO cut the sleeving to get to the broken wire, repaired it (badly) and taped the thing back up.
    Also, The pick up coil wiring harness sleeving was so badly 'cooked' that it was so brittle it cracked and came apart in many places. I put heat shrink along the entire length. (from the ingnition cover up to the plug behind the fuse box)
    I'm afraid that the heat shrink will get brittle and hard fast from all the engine heat.
    I'm looking for that soft vinyl stuff that the wires go in.
    Any ideas?
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    I've looked in vain for that too, with no luck. You can find similar products, but most don't work all that well. Generally, I'll use heat shrink too, but I won't shrink it. McMaster-Carr is a good source for the various sizes/types...
    • Azoroth
      • May 2011
      • 82
      • Idaho Falls, ID
      Is this kinda what your looking for? I work at Oreilly here in Utah. They have a few different sizes. Most of them are kinda big but we can order most anything. Since we have a big warehouse here in town I get 4 deliveries a day. So most stuff I can get in a few hours at least.
      http://www.oreillyauto.com/site/c/de...it+%26+looming
      1980 Yamaha XS1100SG
      1984 Honda VF700F Interceptor
      1967 Yamaha YL2C
      • GLoweVA
        • Jun 2011
        • 1957
        Thanks Azroth, but that's the ribbed wire loom stuff. Not exactly what I'm looking for.
        Thanks Steve, McMaster has something that might work.
        Maybe I'll try the local hardware store and see what's out there.
        The Green Monster
        Got him in '04.
        Scarlet
        Got her in '11
        Hugo
        Cold weather ride
          I forgot about these guys: http://riwire.com/
          Click on 'supplies', then click on 'metal and non-metal conduit'. Still not quite the same as the factory stuff, but pretty close....
          • steelraider
            • Jul 2011
            • 55
            • Spring City, TN
            I don't know if you would want to go this route or not but this stuff is amazing.
            Rescue Tape is a self-fusing silicone repair tape for emergency repairs. Waterproof and resistant to fuels, oils, acids, solvents and salt water.
            It has amazing properties as heat resistence, high voltage insulation, pressure containment (like for a busted radiator hose) etc. It doesn't stick to the item being taped, you pull and stretch it as you apply it and make 2 passes over the area. It fuses to itself and cannot unwrap. you have to cut it length wise to remove it. Another cheaper version is "Tommy Tape". I think in most instances it would work as well. This is someting to put in every tool kit you have for emergencies. I have used it for years to tape up and waterproof all electrical and RF connectors on the antennas I use in Ham radio. TRust me, this stuff works!!
            I am in no way affiliated with this product, just a happy customer.
            Larry Walker
            Ham Radio kw4a
            ex Submarine Sailor (8 yrs)
            Dirt Rider 1970-1980
            Sreet Rider Touring 1980-2000
            Couch Potato 2000-Present
            1980 XS1100 Standard
            1979 XS650 Special
            2000 BMW R1150GS
            • ManagerMike
              • Mar 2010
              • 445
              • S.E. Michigan
              I use that stuff too, I used it on the carb mounting boots to cover up the surface cracks. Home Depot carries it as well under a different name.
              '78 E "Stormbringer"
              • GLoweVA
                • Jun 2011
                • 1957
                Thanks Steve. That's about as close as I've seen so far.
                As soon as I find something that is just about as close to OEM, I'll post it for all those who need to replace theirs.
                The Green Monster
                Got him in '04.
                Scarlet
                Got her in '11
                Hugo
                Cold weather ride
                • trdriver71
                  • 360
                  • Edmonton Alberta
                  if you look at the picture closely it is the fiber loom stuff just like that site steve mentioned.
                  '79 XS11SF
