Did a little research on XJ brake parts
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    Since I'm in the middle of my XJ restoration, and since I have no worries about the "go" part of it, I wanted to make sure that the "stop" systems works as well. So, I went searching for braking system re-build kits as well as pads. Following is a list of MC and caliper re-build kits and pads, and the other bikes that use the same parts:
    XJ Front Calipers o-rings and piston
    (Kit not listed w/out piston. Found the seal kit w/out piston on ebay, Part #2G2-W0047-00)
    This Yamaha 4W1-W0057-00-00 PISTON ASY,CALIPER part is also used on these models and components:
    1981 XJ550H FRONT BRAKE CALIPER XJ550H
    1981 XJ750RH FRONT BRAKE CALIPER
    1981 XS1100LH FRONT BRAKE-CALIPER
    1982 XJ1100J FRONT BRAKE - CALIPER
    1982 XJ550J FRONT BRAKE CALIPER XJ550J - K
    1982 XJ550RJ FRONT BRAKE CALIPER
    1982 XJ750RJ FRONT BRAKE CALIPER
    1982 XV920J FRONT BRAKE-CALIPER
    1983 RX50K FRONT BRAKE - CALIPER
    1983 RX50MK FRONT BRAKE - CALIPER
    1983 XJ550K FRONT BRAKE CALIPER XJ550H
    1983 XJ550K FRONT BRAKE CALIPER XJ550J-K
    1983 XJ550RK FRONT BRAKE CALIPER
    1983 XJ750RK FRONT BRAKE CALIPER
    1984 RX50L FRONT BRAKE - CALIPER
    Front Master Cylinder Re-build kit:
    This Yamaha 4H7-W0041-00-00 CYL KIT,MASTER part is also used on these models and components:
    1980 XJ650G FRONT MASTER CYLINDER
    1981 VIRAGO 750 - XV750H FRONT MASTER CYLINDER
    1981 XJ650H FRONT MASTER CYLINDER
    1981 XJ650LH FRONT MASTER CYLINDER
    1981 XS1100LH FRONT MASTER CYLINDER
    1982 VIRAGO 750 - XV750J FRONT MASTER CYLINDER
    1982 XJ1100J FRONT MASTER CYLINDER
    1982 XJ650J FRONT MASTER CYLINDER
    1983 MIDNIGHT VIRAGO 750 - XV750MK FRONT MASTER CYLINDER
    1983 RX50K FRONT MASTER CYLINDER
    1983 RX50MK FRONT MASTER CYLINDER
    1983 VIRAGO 750 - XV750K FRONT MASTER CYLINDER
    1983 XJ650K FRONT MASTER CYLINDER
    1983 XV920K FRONT MASTER CYLINDER
    1983 XV920MK FRONT MASTER CYLINDER
    1984 RX50L FRONT MASTER CYLINDER
    1987 VIRAGO 535 - XV535T FRONT MASTER CYLINDER
    1987 VIRAGO 535 - XV535TC FRONT MASTER CYLINDER
    1988 VIRAGO 535 - XV535U FRONT MASTER CYLINDER
    1988 VIRAGO 535 - XV535UC FRONT MASTER CYLINDER
    1990 VIRAGO 535 - XV535A FRONT MASTER CYLINDER
    1990 VIRAGO 535 - XV535AC FRONT MASTER CYLINDER
    1993 VIRAGO 535 - XV535E FRONT MASTER CYLINDER
    1993 VIRAGO 535 - XV535EC FRONT MASTER CYLINDER
    1994 VIRAGO 535 - XV535F FRONT MASTER CYLINDER
    1994 VIRAGO 535 - XV535FC FRONT MASTER CYLINDER
    1994 VIRAGO 535 - XV535SF FRONT MASTER CYLINDER
    1994 VIRAGO 535 - XV535SFC FRONT MASTER CYLINDER
    1995 VIRAGO 535 - XV535G FRONT MASTER CYLINDER
    1995 VIRAGO 535 - XV535GC FRONT MASTER CYLINDER
    1995 VIRAGO 535 - XV535SG FRONT MASTER CYLINDER
    1995 VIRAGO 535 - XV535SGC FRONT MASTER CYLINDER
    1995 XV5S5SGC FRONT MASTER CYLINDER
    1996 VIRAGO 535 - XV535H FRONT MASTER CYLINDER
    1996 VIRAGO 535 - XV535HC FRONT MASTER CYLINDER
    1996 VIRAGO 535 - XV535SH FRONT MASTER CYLINDER
    1996 VIRAGO 535 - XV535SHC FRONT MASTER CYLINDER
    1997 VIRAGO 535 - XV535J FRONT MASTER CYLINDER
    1997 VIRAGO 535 - XV535JC FRONT MASTER CYLINDER
    1997 VIRAGO 535 - XV535SJ FRONT MASTER CYLINDER
    1997 VIRAGO 535 - XV535SJC FRONT MASTER CYLINDER
    1998 VIRAGO 535 - XV535K FRONT MASTER CYLINDER
    1998 VIRAGO 535 - XV535KC FRONT MASTER CYLINDER
    1999 VIRAGO 535 - XV535L FRONT MASTER CYLINDER
    1999 VIRAGO 535 - XV535LC FRONT MASTER CYLINDER
    2000 VIRAGO 535 - XV535M FRONT MASTER CYLINDER
    2000 VIRAGO 535 - XV535MC FRONT MASTER CYLINDER
    XJ Rear Caliper O-Ring Seal Kit (No piston)
    This Yamaha 2G2-W0047-00-00 CALIPER SEAL KIT part is also used on these models and components:
    1978 XS750SE FRONT DISC BRAKE - CALIPER
    1978 XS750SE-31 FRONT DISC BRAKE - CALIPER
    1978 XS750SE-311211 FRONT DISC BRAKE-CALIPER
    1979 RD400F FRONT DISC BRAKE - CALIPER
    1979 RD400F REAR DISC BRAKE - CALIPER
    1979 XS1100SF FRONT DISC BRAKE-CALIPER
    1979 XS750SF FRONT DISC BRAKE - CALIPER
    1980 XJ650G FRONT BRAKE CALIPER
    1980 XS1100LG FRONT BRAKE - CALIPER
    1980 XS1100SG FRONT BRAKE CALIPER
    1980 XS400SG FRONT BRAKE - CALIPER
    1980 XS850LG FRONT BRAKE-CALIPER
    1980 XS850SG FRONT BRAKE CALIPER
    1981 VIRAGO 750 - XV750H FRONT BRAKE CALIPER
    1981 XJ650H FRONT BRAKE - CALIPER
    1981 XJ650LH FRONT BRAKE - CALIPER
    1981 XS1100LH REAR BRAKE CALIPER
    1981 XS1100SH FRONT BRAKE - CALIPER
    1981 XS400SH FRONT BRAKE - CALIPER
    1981 XS850LH FRONT BRAKE - CALIPER
    1981 XS850SH FRONT BRAKE CALIPER
    1982 VIRAGO 750 - XV750J FRONT BRAKE CALIPER
    1982 XJ1100J REAR BRAKE CALIPER
    1982 XJ650J FRONT BRAKE CALIPER
    1983 MIDNIGHT VIRAGO 750 - XV750MK FRONT BRAKE CALIPER
    1983 VIRAGO 750 - XV750K FRONT BRAKE CALIPER
    1983 XJ650K FRONT BRAKE CALIPER
    1983 XV920K FRONT BRAKE - CALIPER
    1983 XV920MK FRONT BRAKE CALIPER
    XJ Rear Brake Pads:
    This Yamaha 4W1-W0046-00-00 BRK PAD KIT part is also used on these models and components:
    XJ Front Brake Pads:
    This Yamaha 23W-W0045-01-00 BRAKE PAD KIT part is also used on these models and components:
    1981 XJ550RH FRONT BRAKE-CALIPER
    XJ Rear MC Re-build kit - made of unobtanium:
    This Yamaha 10M-W0042-00-00 CYL KIT,MASTER part is also used on these models and components:
    1982 XJ1100J BRAKE
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
