How do I clean the piston crowns?
  • FormerGlory
    • Oct 2011
    • 32
    • Windsor, Colo.
    Hello there, newbie here. Currently restoring my '80 XS1100S. Engine is out and all parts are at the painters and powder-coater.
    The head has been completed (sonic cleaned, milled, valves and seats ground, and new valve seals). The lower end is in great shape so I don't want to pull the pistons...however the crowns have a thick layer of carbon buildup. The soot ring is very brittle and most of it came loose when removing the head gasket.
    What is the best way to clean each crown and get them clean and shiny again without removing the pistons? The manual just says to "clean them" without any other details.
    Thanks
    I'm sorry I don't have direct experience with this engine, but aren't you concerned that the new head will cause leaking at the rings?
      If you have the head off, it's not that much more work to pull the cylinders to get easy access to the pistons. But if you're determined not to do that, the best method is to bring each piston up to TDC and clean the carbon off. For the actual cleaning, I'd hit it with a flat scraper to get the chunks, then follow up with a maroon scotchbrite pad. You'll never get them spotless, but this will clean off 98% of it. You will need to move the piston up and down a few times to clean out the 'gunk' that will collect between the top ring and the top of the piston (and you'll never get quite all of it), then flush it with some light oil.
      DO NOT use any sort of silica-based abrasive (sandpaper), as this can leave particles in the bore.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        • Fort Myers, Florida
        Steam Jenny
        Thanks
        Does the guy at the paint shop (or anyone you know) heav a small Steam Jenny? If so, take each piston to TDC, steam "across" the top of each one (across is to not force excess steam into the motor) a good Jenny will make them look and work like new. If you do sand, scrap or do any thing abrasive you will rough up the surface and cause more carbon build-up and posable detonation down the road. Open the oil fill cap and do it in the sun (even if it is cold out) and the steam will evaporate and not hurt anything, wont hurt the powded coat if it is already done, just make sure you only hit the pistons tops, a couple secounds each and "like new"
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
        • FormerGlory
          • Oct 2011
          • 32
          • Windsor, Colo.
          Thanks to all, appreciate the insight. I'll look for a Steam Jenny.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Steam cleaning
            I did a surch for Evans Co. and came up with this:
            http://www.cylex-usa.com/company/joh...h-8347366.html
            Don't know how close or $$$$ but might help. If you have other parts that need cleaned, ie frame etc, this will take off any grease, dirt and 30+ years of anything
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
            • Rickrod3
              • Jun 2009
              • 721
              • Oakland, New Jersey
              Supose you did remove the pistons would it be okay to use a buffing wheel?
              I would do a soap and water wash after.
              TIA
              Rick
              650SF
              XS1100SG Project bike
              • petejw
                • 2269
                • sydney australia
                hi formerglory,
                as a cpl of others have said, id remove the barrels
                and clean the pistons properly, if u have a thick layer
                at the top of the piston, ull more than likely find carbon
                in the ringlands, side of the pistons, the pistons also have oil holes under the
                oil rings and they tend to block up as well.
                heres a link to mine
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                1981 xs1100 RH (aus) (5N5)
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  Paint prep.
                  I would use a good paint prep. to clean after buffing, leaves them clean and ready to instell
                  TIA
                  Rick
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                  • Rickrod3
                    • Jun 2009
                    • 721
                    Thanks for the tip
                    650SF
                    • LuckyEddie
                      • 166
                      • Middleville, Michigan
                      cleaning piston crowns
                      While I had the head off my 80 MNS, I used a soda blaster to get the carbon off the pistons. Worked great, nice and shinny. Do it outside though, gets everything dusty.
                      LuckyEddie
                      1980 XS1100LG Midnight special
                      1982 XV750J Virago
                      1976 GL1000
                      1978 GL1000 Supercharged
                      1981 XV920RH (chain drive)
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        Polish
                        With the head off, it is so easy to remove the jug's A great chance to check all the cyls and rings and clean / fix anything and everything I would (and I know I will get heck for this) check / hone the cyls, pop the pistons off (easy to do with a home made pin press, check Clymer manual, couple of bolts and nuts) Sounds like you have a bench wheel, so polishing the tops of the pistons is a great idea IMO, then spray clean with Klean Strip auto prep, cheap spray can at any auto supply store, leaves clean, ready to install
                        TIA
                        Rick
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                        • petejw
                          • 2269
                          • sydney australia
                          removing the pistons from the con rod isnt that hard and
                          only needs a slight tap with a hammer and extension to remove.
                          if ur polishing the pistons using a buffer and rogue i wouldnt be
                          using any cleaner, the pistons are already clean and the buffer/rogue
                          puts a film over the alloy to protect it, removing the film will cause
                          the alloy to anodise.
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            Pete
                            you know I love you Pete, but, the reason I said to spray clean with prep clean "instead" of washinig with soap and water is, prep clean leaves no oxidation and removes any abrasive compound that might remain
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                            • petejw
                              • 2269
                              • sydney australia
                              lol,
                              i wouldnt wash em in soap and water either,
                              if u use the buffer properly without overloading it
                              with compound there shouldnt be anything left
                              after buffing and if there is a soft polishing cloth would
                              be enuff to remove any xs compound.
                              isnt the prep clean a wax and grease remover?
                              that would also remove any film left by the compound/rogue
                              have a look at my pistons they were just
                              buffed and left alone after that, ive got over 500k's on them
                              atm and they look as good as they did when i put them in.
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
