I have found a '78E engine to put into my '80G and have some questions. The link below shows the pickup coils and advance for both engines. The '78 is corroded bad and I would like to put the '80 ignition on the '78 engine and use the '80 ignition box. The '80 looks like the bolts need to be drilled out to get the pickup assembly off? Is this some kind of emissions foolishness? How about the carbs - my '80 carbs should work just fine on the '78 engine, right? <fingers crossed>.
As always - Thanks for help.
The carbs on the left are solid white power inside, while the right are just varnish.
