Running great finaly!!
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Ok, 1st, thanks again to all who helped Put all back togather, hooked up feild tank, gas ran out of all the carbs again Took a break, looking for some strong rope and a chair or a sharp knife Drained carbs from the bottom, dried out cyls and spark plugs, installed OEM tank on a hunch, started right up, ran great, idled great, NO LEAKS I don't get it either but Now just imposable to get to all the screws to sync carbs, but rund so good, I DON"T CARE, thanks again
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    Just remove and flip your
    OEM tank around placed where seat was, hook up fuel lines and sync/set idle mix.
      I am guessing that it was a float hung up on a gasket or something like that causing it to flood and then not now. I have never used a separate tank, always done just what Moto described.
      The only other thing that would make sens is if you hung the fuel tank way up high and had lots of fuel in it, it might possibly have had more pressure against the float valve than the floats can create. But I doubt that really.
      Just glad you got it running good again. I know what a frustration it can be to get the carbs working right, and how nic eit is when they finally cooperate!!!
        Awesome. It could have been that aux. fuel tank all along causing the flooding.
