wondering which way to go
  • bcknblkbird
    • Mar 2009
    • 124
    • jonesville nc
    having fork dive problems. new seals, oil two years ago. feels like the forks move too freely for me. been reading threads on this problem and found lots of options. just wondering which would be the best way to go? i don't ride too agressive. of course it's an xj with air forks that i think leak. air that is.thanks for your input.
    Make some preload spacers out of some 3/4" PVC pipe. Start with about 3/4" long for each fork and make sure you use a washer between the PVC and the spring.
    • petejw
      • 2269
      • sydney australia
      hi bcknblkbird,
      id check the oil level in the forks
      if its a dampening problem,
      not sure what model forks u have,
      but adding a spacer to increase the pre load will affect
      the sag on the forks, which wouldnt be a problem if the
      sag is out.
      if u do a search on youtube theres a cpl of
      good videos of suspension set up, there on a modern bike
      but the principles are all the same.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
        Switching to a heavier weight oil will help a bit as well as increasing the oil level by 25cc. If you have the $$ the correct way to reduce dive and to improve overall handling would be to get new stiffer springs. 30 yr old springs get weak but can be compensated for somewhat with the addition of the preload spacers as I mentioned.
        • 'OlGuiltyBoy
          • Oct 2011
          • 174
          • Manassas, Va.
          We all know what 'Ol Guilty is gonna say ...
          Trash 'em, and swap on some Hayabusa forks and triple tree ... Basically a direct swap except for a tapered roller bearing, all you have to do is trim a few mm off the inner diameter and youre set.
          ~I had a dream last night that I was banned from this site for some reason...
          ~Jay
          Guilty Ones M.C.
          Manassas, Va.
          1980 Standard G
          2001 CBR 929RR
          • GLoweVA
            • Jun 2011
            • 1957
            • Virginia Beach, VA.
            Banned ??? I hope not.
            Jay, I wouldn't worry about it. Even as a purist, I kinda like the 'fab' guys input on modifying things. It gives me a different perspective on my bike.
            Plus when it comes to figuring out what might work, you guys have 'been there, done that' so, at least, I value your input.
            80G (Green paint(PO idea))
            The Green Monster
            Got him in '04.
            bald tire & borrowing parts
            Scarlet
            Got her in '11
            Ready for the twisties!
            81H (previously CPMaynard's)
            Hugo
            Cold weather ride
            • bcknblkbird
              • Mar 2009
              • 124
              • jonesville nc
              i'm leaning towards progressive springs, if so does the tapered end go in first? heavier fork oil also? thanks for all the info !
                It does not matter which way the Progressive springs go in, they function the same either way, close wound end at the top or bottom. I would up the fork oil weight to 15W or 20W also. With this setup, you won't have to fool with air pressure ever again.
                • 'OlGuiltyBoy
                  • Oct 2011
                  • 174
                  • Manassas, Va.
                  Why thank you sir ...
                  ~Jay
                  Guilty Ones M.C.
                  Manassas, Va.
                  1980 Standard G
                  2001 CBR 929RR
                  • cywelchjr
                    XS-XJ Super Guru(Deceased)
                    • 4450
                    • Sacramento, CA
                    Jay, the only thing I don't understand with some of those that say do that, is putting on haybusa forks and hardtailing the back. So you improve the front end, and then destroy the back end handling. It totally makes sense to me if you did the forks and did a mono shock setup or something like that, and even doing chain drive (although I really think there are better platforms out there if you really want chain drive, but that's just my opinion) has it's level of sense. I can even believe it or not see the draw of the jockey shift (not for me, but I can see where some are drawn to it).
                    It might not be something we would do ourselves, or something we would want to own, but if it's done well, we WILL admire the job and pat you on the back for a job well done. If you screw it up, we WILL talk bad about you too though. It goes both ways.
                    I don't know what yours was like before you started, but now I've heard some things described that say it may actually be one of the ones best chopped to keep it on the road (cracked frame parts make it one of those). To me, the minute you talk frame damage you have to consider that it might be time to talk bobber. Yes, I would consider doing a bobber if I had one that had that type of damage.
                    • 'OlGuiltyBoy
                      • Oct 2011
                      • 174
                      • Manassas, Va.
                      Beauty is in the eye of the beholder... Give me some time - and it will grow on you, you will like it and you will say "that's a nice bike"
                      ~Jay
                      Guilty Ones M.C.
                      Manassas, Va.
                      1980 Standard G
                      2001 CBR 929RR
                        I had a completely sacked front end last year. I was ignoring the problem until I dumped the bike.
                        Mine is fixed and fixed good. I installed the Race-Tech Gold Valve emulators and custom wound springs from Traxxion Dynamics. I also installed new shocks with correct springs for my weight. The difference is nothing short of amazing.
                        I just got some tuning advice from Mike Wiley of Race-Tech when I was at the Barber track. I'm sure now it's going to be much better after taking the tuning advice.
                        I could have achieved the same results (or better) by having Traxxion Dynamics do the entire set-up. I would have saved a lot of $$$$ and headache.
                        In the end, I am extremely happy with my new suspension! I understand this may be too extreme for most here, but I like the bike and enjoy riding it a lot. This is the only way to go, short of what BikerPhil did. (FJ forks)
                        I have posted the details of my enhancement here before.
                          Marty, what kind of Wiley tuning advice did you get and will you share?
                            I followed the supplied instructions during installation. I drilled the holes out in the damper rod. There were four of them. My ride is pretty harsh. I can ride aggressively, but I'm not soaking up the bumps as I should.
                            Mr. Wiley told me I need at least six holes in the damper rod. I'm not moving enough fluid. He gave me a new top piece to the emulator and told me to drill two holes it it and give it a try. He also supplied me with some more springs. Importantly, I learned that the emulator is set at three turns and each half turn should make a big difference. This was not in the instruction sheet as I recall. He told me first I need to move more fluid, try the new top, and if it isn't satisfactory, drill two more holes in the damper rod. (it needs to be ruined or removed from all control) At first service, he recommended 15W fork oil.
                            Marty (in Germany)
                              Thanks, Marty!
                              Traxxion Dynamics will do the whole enchilada or would I have to buy the emulators ahead of time and send them along with the forks?
