XJ brakes
Garry,
I have sent Gregg the XJ brake hardware to install on his 79XSF.
He wants to try to connect all three calipers to the XJ rear master cylinder. It will be easy enough to do, he can just use the front brake junction block located on the lower triple clamp. He will just need to remove the hose leading from the front m/c, and attach the line from the rear m/c to the same place the front one came from. If he wants to use the XJ set up (rear m/c to l/f caliper) he'll need to change out the junction block to the XJ's. I agree with the pressure increase with three calipers in the circuit, but I'm concerned that the m/c will not be able to move a large enough volume of fluid to (I'm at a loss for the correct term) overcome the small distance that the pistons retract back into the caliper bore when the brakes are released. Does this make any sense? I'm not trying to start a 'pissin' contest here, just voicing my concern over trying to link all three calipers to one m/c. It may work. I've been wrong before and I'm sure it will happen again, more often than I would like.
Let's wish him luck, and help him out if he should ask for it.
Garry,
