Hi,
Keep in mind here that I am a newbie and my terminology and my understanding of the inner workings of a motorcycle may be incorrect.
My front brakes were locked so I tried to verify where the problem may be. With some advice given from some of the members in this forum (in another thread) I went ahead and verified a few things on my brakes.
I had removed both front caliper assmebly off the rotor, as well as the pads from caliper assembly.
Not knowing earlier, I had pressed on the front brake lever with the caliper off the rotor, this extended the piston and now the opening where the brake pads should fit in is about a 1/4 inch. How can I push the piston back into the piston assmbley. I tried to unscrew the bleed screw and try to push the piston back a bit but could not budge it at all.
How do you unseize a seized caliper?
I unscrewed the bleed screw on the right caliper (removed it completely, so I guess now I will eventually need to bleed the brakes and replace the fluids) and there was no pressure build up, in fact it was pretty dry. When I pulled on the front brake lever a bit of oil came out. Put screw back.
I could not see the hydraulic level in the front master cylinder gauge. I tried to remove the plate off the front master cylinder but noticed that the screw head was all messed up, that is I was unable to remove the screws. How can I remove the plate now?
Just to confirm something, the front brake lever controls the front right caliper and the brake pedal controls the front left and rear calipers, correct?
I also unscrewed the front left caliper and the rear caliper bleed screws and no pressure build up. I also noticed that after pressing the rear brake pedal, the rear brake locked up.
I tried to verify the hydraulic level on the rear master cylinder gauge but could not see anything. So I removed the 3 screws and removed the top plate. First thing I saw was a metal plate with a rubber seal. There was a bit of rust on the rubber seal. I lifted the seal up and saw that there was a bit of hydraulic oil, how much oil should there be in there, should the oil be filled until just under the seal or should there be oil on top of the seal.
Just a note, all the verifications above were done with no power to the bike, the brake system works on mechanical/hydraulics and requrie no electrical power, correct? (told you I was a newbie).
Sorry for the short story and the many questions.
I have already ordered the CD from rockjok, but I guess I should go to the nearest book store and pick up any book on fundamental motorcycle mechanics.
Any advice and direction would be greatly appreciated.
Thanks
Peter
Thanks
Peter
