FRAME QUESTION...Does this look right???
  • jmacsuga
    • Oct 2011
    • 58
    • Spokane, Wash.
    I am beginning to do the cleaning...I posted on "Purchased XS110....???" or something like that, but this is what I don't understand. Bottom frame slides into the top frame, and previous owner put on hose clamps. Is this the way it is supposed to be???? Can you take a look at this photo, and give me some advice??? http://jimphoto.freeprohost.com/Yamaha/yam021.JPG
  • 11Rider
    • Aug 2010
    • 331
    I doubt both front down tubes of the frame are busted and held together with hose clamps if that's what you're wondering. I'd have to guess there was some kind of accessory/bar/lines that were attached to the frame vial the hose clamps at one time. Just a guess though!
    '79 XS11 Special, fork gaiters, Uni pods, 45 pilots, 140 mains, ditched the octy, solo seat, T kat fork brace
    Purrs like a kitten, runs like a scalded cat
    • Barnfresh
      • Mar 2009
      • 160
      • Abilene, TX
      That looks normal. The hose clamps probably held the mount for a fairing.
      When the horse is dead, dismount.
      Bagapotomus - '80G Attempted Rescue, '78 Engine, Vetter Bags and Trunk.
        That's that I was thinking.
          • 9980
          Back off and give us a better view of what that is.
            • 3180
            +1 on the clamps being for a fairing.
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              I've got hose clamps right there, but they are for my fairing bracket. You might want to check to make sure those welds are good though.
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
              • cywelchjr
                XS-XJ Super Guru(Deceased)
                • 4450
                • Sacramento, CA
                Yep, those look like the hose clamps used for the lower part of a Vetter fairing mount. Sometimes it easier to just leave them one and tighten them back up when taking the mount off then take them off.
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  • Fort Myers, Florida
                  It looks like a tube inside a tube? Can't tell from photo if it is just an acc. ad on or if two tubes are being joined with hose clamps I so, get them weilded befor riding Will watch for better pic's with more info
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                    • 3180
                    Not to worry it looks exactly as it is supposed to!!!
                    • jmacsuga
                      • Oct 2011
                      • 58
                      • Spokane, Wash.
                      Stupid Me!!!! False alarm!!!!
                      Hi, Guys! Well, I took the stupid clamps OFF,and examined the frame underneath, and well, it looks normal. The frame from the bottom goes up to the top, with a welded bracket on the outside of the frame and welds to the top of the frame. All is good!!! I will post photos tomorrow. Thanks for your information!!!!
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        Ok
                        Ok, the top half of the tube in the pic has a larger dia. the the lower half Is this how some XS1100's come from the factory Mine has one piece tube all the way down on both sides No weilds or connections
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                          • 3180
                          I went out to the garage and took a couple of pics for you. Hope this helps!
                          Frame of a 78E
                          Frame of a 81LH
                          A 78E with fairing installed
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            Yes
                            Yes, that helps, looks stock from those pic's, thanks, happy bikeing
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
