midrange power
  • mack
    • 2411
    • Ontario, Canada
    dialed in
    When it's dialed correctly there should be no dead spots in the tach. Even at 2K in fifth gear, if you roll on the throttle it will come to life big time.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • imcgyver
      • Oct 2011
      • 27
      • Denver, COLO.
      Well I put the stock pilot jet back in and now have some pickup between 2 and 3k I am happy with that, runs great, But nowduring the test ride it died due to no spark after an hour I got spark again any ideas?
      the po installed a Accel super coil kit 140403 with NGK Iridium plugs. ignition fuse good whil I had no spark, after I got the seat off I got spark so I could not troubleshoot from there, Coil or TCI?
      Thank you for your time and response.
      Ron
        Coil or TCI?
        Neither........ likely pick-up coil wire(s).
        • imcgyver
          • Oct 2011
          • 27
          • Denver, COLO.
          I hear about broken wires in the pickup coil assy, any common spot for the breaks or?
          Ron
            • 5055
            The spark plug connectors can be suspect. I have seen them go bad only when hot.
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              I had something similar happen to me. bike died on my way out the driveway. When I got off the seat, I got spark.
              I figured it was a loose connection near the fusebox, or the plug into the TCI.
              Hasn't come back yet.
              Hope this helps.
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
                The longer sections of wire connected to the advance assembly........both hands pull on them bout every inch.........if insulation stretches, ther's a break.
                • 81xsproject
                  • 3185
                  • Fortuna, CA
                  I know your on to spark problems now, but I thought I would make a recommendation. Once you get your spark problem worked out, try bringing that main down to a 117.5. That with the 42.5 pilot should be about right.
                  '81 XS1100 SH
                  Sep. 12th 2015
                  RIP
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    no spark
                    Not that I want to go against the grain of this thread, but if he's got NO spark at all, then that would mean that both wires on the advance would have to go bad at the same time.
                    I do agree that this is a common failure on our bikes and had to fix one of mine, but if he's lost all spark, then I think the issue may be elsewhere.
                    The Green Monster
                    Got him in '04.
                    Scarlet
                    Got her in '11
                    Hugo
                    Cold weather ride
                    • cywelchjr
                      XS-XJ Super Guru(Deceased)
                      • 4450
                      • Sacramento, CA
                      Actually there are several documented cased of a single pickup coil failure causing a no spark condition. Nobody is sure why, but it has been known to happen.
                        Originally posted by cywelchjr
                        Actually there are several documented cases of a single pickup coil failure causing a no spark condition. Nobody is sure why, but it has been known to happen.
                        That's probably the 'auto shut off' function in the TCI operating; remember, if the motor isn't turning (i.e. the TCI is getting a signal from the pick-up coils), after a 'few seconds' the TCI disconnects power to the coils to prevent damage. If you have a clean break in one of the wires (rather than an intermittent connection), the TCI will think it's not turning....
                        • Rickrod3
                          • Jun 2009
                          • 721
                          • Oakland, New Jersey
                          I for one experianced this.
                          Rick
                          650SF
                          XS1100SG Project bike
                          • GLoweVA
                            • Jun 2011
                            • 1957
                            single pick up coil failure
                            Wow, it never ceases to amaze me the knowledge and experience of all you guys. Once again, I've learned something new about my bike.
                            Thanks again for sharing all your knowledge.
                            I love this site.
                            The Green Monster
                            Got him in '04.
                            Scarlet
                            Got her in '11
                            Hugo
                            Cold weather ride
                            • imcgyver
                              • Oct 2011
                              • 27
                              • Denver, COLO.
                              Well I found a broken orange wire from the pickup coil, what is the best repair?
                              longer wire connected?
                              wrap longer wire around bottom of clamp for movement?
                              or?
                              any ideas would be appreciated.
                              Ron
                                That soft flexible wire used for electrical multimeter wires works best.
