I had hoped to not have to do the clutch but it seems like that may be what's needed. Now that I have the engine running properly I'd discovered what seemed to be a power curve oddity around 7K RPM & up where the engine would rapidly speed up & it was during the pull from the power band. I tend to shift below that so it wasn't an issue to me but I knew it would happen if I were under WOT in that range. I finally decided it was the clutch beginning to slip.
Since I put 2,500 miles on it after doing the ring job I figured it was past break-in and put Amsol for wet clutch bikes in the engine and within a hundred or so miles of operation the clutch now slips around 6K RPM under WOT. Other than that it doesn't slip so I don't have to deal with it immediately and can put that on the to do list before spring.
The thumbwheel adj by the clutch grip is set to give about 1/2" of pull at the end of the grip before it begins to find resistance. Pulling the grip in very little is enough to engage the gears without effort. When the bike is idling, in 1st gear and I have the grip in all the way, it is difficult to bring the bike backward, it's like there is a slight bit of engage to the clutch even when it's not bearing down on the plates & it's always been like that.
So with this, I'm wondering what my best option to do is; is there an internal adjustment that might help? Is it likely the only issue is the springs are weak after 30 years & new springs should fix the issue? Where can I find the best price on whatever parts are needed?
Idears?
Idears?
