Setting Pick up coils
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    Does anyone know the proper gap to set between the reluctor and the pick up coils.
    I'm replacing mine and I forgot to take notice of what it was originallly set for.
    TIA
    Rick
    650SF
    XS1100SG Project bike
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    Spec is .7mm
    .5mm works for me
      • 9980
      That's about .021 inches for those without metric feeler gauges.
      • Rickrod3
        • Jun 2009
        • 721
        second question
        Thanks for the reply.
        Are the pick up coils a wound magnet or a metal magnet with wires attached?
        How common is it for them to fail?
        Actually thats second and third questions.
        Rick
        650SF
          • 9980
          Wound.......
          • Rickrod3
            • Jun 2009
            • 721
            Originally posted by BA80
            Wound.......
            I mean wound as in winding it is a proper word
            650SF
              • 9980
              Yes, I understand. I was answering you. They are wound electromagnets.
              • Rickrod3
                • Jun 2009
                • 721
                Sorry.
                I appreciate the answer.
                Thanks.
                650SF
                • cywelchjr
                  XS-XJ Super Guru(Deceased)
                  • 4450
                  • Sacramento, CA
                  Actually I don't think they are electomagnets, they are coils, the reluctor is a magnet and it causes a pulse in the coil due to the magnetism of the reluctor passing the core of the coil.
                    • 9980
                    The reluctor may retain some magnetism because of it's enviroment but it's the other way around Cy. The signal is produced when the reluctor passes the electromagnet (coil) and breaks the field.
                    • Rickrod3
                      • Jun 2009
                      • 721
                      What your saying makes sense.
                      I ask because the piece of metal facing the reluctor is magnetic. Maybe it picked it up from the reluctor
                      650SF
                      • cywelchjr
                        • 4450
                        • Sacramento, CA
                        Ok, we are BOTH wrong. The reluctor is indeed not a magnet, but the coil is NOT an electomagnet, it is a coil with a steel/iron core with a small magnet at the far end from the reluctor. The reluctor passing the end of the coil, causes the magnetic field to move which causes the change in resistance (actually it induces a current). Here is a link to information about it on megasquirts site that talks about it, since pickup coils are ONE of the things that can be used as a trigger for the megasquirt.
                          • 9980
                          I got to thinking about that after I posted. Your right, thats the way all pickup coils are.
                          Brain fart.
