I need a Carb Jet No. clarification
  • W1CKED one1
    • Sep 2011
    • 5
    Hello everyone. 1st of all just wanted to say what a great and amazing site this is. There's alot of interesting information and many helpful members.
    ....I decided to rebuild my carbs on a 1978e XS11. Broke everything down and started to look and compare jet sizes through some of the fourms and members set ups. I plan to use a #45 pilot jet and #145 main jet on individual pod filters and the current 4-1 exhaust with no baffles (I've taken many pictures of the break down but still trying to figure out how to post them).
    On the Yamaha 1978-1981 Clymer Manual Pg.145 it states the specs on the Main Jet No. to be 137.5
    Starter Jet No. 40
    Pilot jet No. 42.5
    Air Jet -main 140
    Air jet - pilot 180
    Is the Main Jet No. 137.5 also considered the Emulsion tube, because I have not seen this number on any of the jets?
    The air jet -pilot is listed at 180. On Clymer (Pg 147) #35. is the Air Pilot Jet. Located in front of the carbs where the pod filters would be attached. The numbers on the air jet on mine is 210from PO. Should I replace the jet back to 180?
    Bike won't idle and takes a while to start. Brand new plugs with only 2 minuets of running time turned to the tips becoming completely lean (white) and burnt (powdery black) around the ceramic part of the plugs. Then again, I used starting fluid to start it.
    All of the other jet no.'s match.
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    Hey Wicked,
    That's another typo in the Clymer manual, they fail to mention it in the listing. In the diagram the 'emulsion tube", known in the Yamaha diagram as the main nozzle, is #17 and it's held in place by the main jet. Yet it comes out the diaphragm side after you unscrew the main jet. There's also a thick washer in there between them, don't lose it.
    Look here for a clearer picture:
    http://www.boats.net/parts/search/Ya...TOR/parts.html
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
    • W1CKED one1
      • Sep 2011
      • 5
      Thanks Cobia. Got all of them out. So if i wanted to increase the flow I would replace the screw on top of the emulision tube that has 140 printed on it to 145?
        The '78s were jetted different and the clymer never really care to note that in their book. Stock '78 jetting was 45 pilot, 137.5 main, and a 210 air jet.
        • W1CKED one1
          • Sep 2011
          • 5
          Thanks Natemoen. It's all clear now. Will the plastic flaots for 80-81 work in replacement for my 78 copper floats?
            Yes they will work, I have floats from a '81s carbs in mine.
            • ManagerMike
              • Mar 2010
              • 445
              • S.E. Michigan
              Just to verify. I have the clymer manual, and a 78. Yes the clymer says it has 42.5 pilots, it does not; they are 45's. It is correct however in regard to the stated 137.5 mains.
              I also have switched up to the 145 mains with pod filters and stacks, with custom 4 into 2 exhaust, and am very pleased with the results.
              '78 E "Stormbringer"
              • yamahansolo
                • Aug 2007
                • 1113
                • jawga
                Seems my 79 had 78 carbs because it has 210 airhets as well but it had 140 mains and what ever the stock size 78 pilots were I for got. . I have zrx carbs now. I love them but hate they are harder to adjust the idle mix screw. Rge older ones were east with the exposed screw
                79 xs11 standard
                8mm msd wires
                tkat fork brace...
                Fox shocks...
                mikes650 front fender
                led's gallore...
                renthal bars
                gold valve emulators
                vmax tensioner
                Rifle fairing
