79SF oil light came on and won't go off.
  • kevkat8
    • Sep 2010
    • 37
    • Cranston,RI
    Hi all,
    Went for a short ride today and noticed that my oil-indicator light was on. Checked my oil and it was low.....Ok. Added about 3/4 qt. and started it up again. oil light went off after a few min but came right back on again and stays on now. When I tap the brakes the brake-tail light comes on and the oil-indicator light goes off or dims a lot. The low oil sensor works as it did tell me I was low on oil. Any ideas where I should start.
    1979 XS1100sf
    kerker 4-1
    TC fuse box
    Tkat fork brace
    I think the oil light doubles as a "tail light burnt out" indicator.
    • kevkat8
      • Sep 2010
      • 37
      • Cranston,RI
      Tail light works and so does brake light as does the trun signals.
      • kevkat8
        • Sep 2010
        • 37
        • Cranston,RI
        What about if the oil preasure switch IS bad. Any test for that?
        1979 XS1100sf
        kerker 4-1
        TC fuse box
        Accel coils
        Tkat fork brace
          Unscrew the switch out of the case and see if it may have gotten plugged by some crud. make sure the oil galley it screws into is clear also.
          • Incubus
            • 1003
            • Austin TX
            Disconnect the wire from your oil sensor. Ground it. Did the light go out? Unground it. Does the light come back on?
            Your oil switch works by completing the circuit. If the light works properly when you ground it without the switch, the switch is bad.
            Or perhaps the wire is loose.
            Patrick
            XS11F (Incubus, daily rider)
            1969 Yamaha DT1B
            • kevkat8
              • Sep 2010
              • 37
              • Cranston,RI
              Thanks guys. I'll play with the switch tomorrow and let you know how I make out.
              • kevkat8
                • Sep 2010
                • 37
                • Cranston,RI
                Well, I started up the bike and the oil light came on and stayed on again. I then just touched the oil sensor and it went off. I disconnected the wire and unscrewed the sensor. Looked clean so I screwed it in again, connected the wire and all is well. Started it up a few more times and it works like it is supposed to. Hmmmmm I'll keep an eye on it.
                Thanks to all for your directions.
                  Sounds like just a bad connection.
                  • Incubus
                    • 1003
                    • Austin TX
                    I love free repairs.
                    Patrick
                    1969 Yamaha DT1B
                    • kevkat8
                      • Sep 2010
                      • 37
                      • Cranston,RI
                      Well I went for another ride, a short one and the oil light comes on again. I pulled off the sensor wire and grounded it and oil light shines bright. When I unground it it glows very dim. Checked continunity of the wire and it tests good. Pulled sensor again and it looks nice and clean with oil on it.
                      Any ideas guys?
                      • Incubus
                        • 1003
                        • Austin TX
                        If the oil light reacted when you grounded and ungrounded the wire I would be inclined to diagnose the problem as being the switch.
                        1969 Yamaha DT1B
                          As Nate mentioned, the oil light doubles as a bad tail/brake light indicator. There's a 'black box' in the wiring that connects to the oil, tail, and brake lights; try unplugging that to see if the oil light problem clears (note that this will cause the taillight not to work, but the oil/brake lights will still work normally). This box will have blue/yellow, black, black/red, yellow, blue, and brown wires going into it. If you have a poor connection here, this could be the cause of the problem. Or the box could be defective, requiring replacement. This is a one-year/model-only part ('79 Special) so may be hard to find if bad. You can bypass/defeat it by jumpering the blue/yellow and blue wires together to make the taillight work, leaving the rest unconnected.
                          This 'light checker unit' only shows up on the wiring diagram; there's no mention of it in the FSM...
                          If the above doesn't clear the problem and the light still glows dimly with the wire disconnected from the sender, then you likely have a bare spot on the wire from the oil sender that is going to ground; you'll have to trace the wire out to find this.
                          • Incubus
                            • 1003
                            • Austin TX
                            Steve, post a picture of this component you speak of. If it is only on SFes, I could possibly help out. I have an SF wire harness and components that doesn't work on my Standards. I tossed some really bad stuff, but maybe I still have that.
                            Patrick
                            1969 Yamaha DT1B
                              I don't have one, so let's see if this works....
