Hey guys,
I have a 1979 XS1100 Special. I have a bogging problem which I have traced back to leaky carbs. I have found gas in the oil and gas out the airbox. I know the petcocks are good. I have cleaned the carbs multiple times, thoroughly.
Specific things I have done:
Carb Floats - I have tested them for leaks and they are NOT leaking
Float Valve - The needle is not deformed and makes a good seal on the valve seat.
Bowl Gasket - The float has clear play and is NOT getting caught on the gasket
On the bench, with the bowls off, I have manually pushed up on the valve and can confirm that it easily shuts off the fuel flow. However, when I fully assemble the carb, the float does not turn off the valve. It subsequently hemorrhages fuel out of the "main nozzle".
I have adjusted the float level tang to an extreme just to test and it makes no difference. I have also adjusted the minimum float level tang (whatever the other tang is called) to prevent the max travel of said tang, again just for testing. These tests have had zero change.
Could the float be sticking on the bowl somewhere? If so, where. Are there other things I can check to diagnose the problem and get a solution.
Gas has for sure made its way into the engine...oil's been changed, and will be changed again before we give it another shot with the carbs on the bike.
