Originally posted by ManagerMike
View Post
Needle Jet Number?
Originally posted by XSessiveForce79 View PostI have a 79F and it has the big bore kit,Pods,and stock exhaust w/o baffles.I believe I am running lean...lots of popping slowing down from highway speed. 5k rpm seems like a wall to me, just starves.
Your PODS filters is a possible big red flag!? You've already taken the carbs out/off, so look at the inside of the cone/pod filter...IF they are the CONE tapered design, not the cylinder or oval style, and see if they have the prominent mounting lip on the inside edge? If so, that can also cause problems due to restriction to airflow at the inlet bell.
However, if your carbs are the 78-79 series, then, most likely your wall is the too small mains! Just trying to cover/eliminate other sources of poor performance.
Without baffles in the mufflers, that could also contribute to popping on decel even with properly jetted carbs. Aftermarket pipes ie. 4-1's that scavange more for the mid/high end rpms are known for popping on decel as well. Setting the idle speed a little higher...~1100 so that the butterflies don't slam completely closed on decel can help reduce popping, along with richening up the pilot jet screw adjustments.
T.C.T. C. Gresham
Another thing is that the stock exhaust baffles are not really removable, well they can be taken out but they aren't ever going back in, so you may not even have a stock exhaust which could cause other issues.Nathan
