Originally posted by mr_misfit138
View Post
It sounds like you have done a thorough job of cleaning the carbs but perhaps along the way the carbs were exposed to carb cleaner and if so, the rubber components could have been damaged. There are O-rings on each side of each butterfly which will be damaged by carb cleaner and if they were never replaced, they're 30+ years old and may have become brittle and leaking or cracked. If so, your idle will never be controllable.
These O-rings are readily available but will require separating each carb body to get to them, at which point you will need to reattach & resync the carbs.
Something to do over the winter and something I neglected to do when rebuilding my carbs this year. Mine aren't leaking but I'm going to replace them anyway because everything else was replaced and these old O-rings will be the first parts to fail.
Also, if you get mercury in your engine, that's not good cause mercury and aluminum don't play nice.
