hey everyone
got myself a 1980 xs11g about 2 months ago, my first bike, and also my first introduction to a vehicle which i will have to service entirely myself. i know nothing about cars/vehicles and i am completely green when it comes to this stuff. my bike has 1,000 different issues, and i will be bringing them all to your attention in the coming weeks, but the big problem for now is the goddamn brakes, which i screwed up myself somehow.
i got a wild hair the other day and decided i'd replace the brake pads. i ordered them long ago, knowing that the brakes i bought it with were severely worn. so the other day i finally got around to attempting to replace the pads. i got the calipers off just fine, but the problem was that i couldn't get them back on the disc because the cylinder was keeping the pads too close together. so i tried to push the cylinder back in with my fingers, didn't work. i reasoned that this wasn't working cuz the system was pressurized, so i unscrewed the hose from the caliper, pushed the cylinder in, and sure enough some fluid came squirting out as i pushed it in. and you all know thats where the problem began...the brakes have been useless since then.
i sought advice from a bike-savvy buddy, the bike's service manual, and this forum. i have tried everything to get it pressurized again, including pouring fluid directly into the caliper (it just spews back out onto the ground) ...the master cylinder (i think? the part with reservoir attached to lever on rt handlebar) is not pulling any fluid through. i unhooked the line and pumped and pumped (with the diaphragm on reservoir), and only a couple drops came through. i tried sucking fluid through with my mouth on the caliper end of the hose, while holding the brake lever in. nothing. does this mean i have a bad master cylinder? i do not have the tools or experience to take the thing apart and clean it, i'll never get it put back together, so that isn't an option. any ideas? i apologize if this has been covered in another thread, if so please direct me to it.
