ordering a new ignition key
  • KA1J
    • 664
    • Groton, CT
    The XJ11 came with a copied key and though it works and one cut from it sort of works, I'm wondering if there's any way of easily ordering or finding out what an original key should be cut like?
    I'd rather use a proper key & maybe that will prolong the tumblers in the ignition.
    Thanks.
  • neJeff
    • Jun 2011
    • 346
    • Nebraska
    Try Motorcyclekeys.com Got a couple from them and they helped quickly with an issue I had. They are in Hawaii but still received very quickly. Think I paid $7.00 and $3.00 shipping
    Current Daily Rides / Projects
    1979 Yamaha XS1100F (since 2015)...Project
    1980 Suzuki GS850G (since 2012)
    1979 Kawasaki KZ400B (since 2013)
      You could take the ign switch off the bike and take it to a good locksmith (not Home Depot) and he should be able to make the correct keys.
      • GLoweVA
        • Jun 2011
        • 1957
        • Virginia Beach, VA.
        I had lost my key once and went to a local locksmith and all I needed was the 4 digit number that was on the ignition switch. He looked up the code and it gave him the depths of the notchs to cut in the key. 4 or 5 dollars later, BAM I had a new key.
        80G (Green paint(PO idea))
        The Green Monster
        Got him in '04.
        bald tire & borrowing parts
        Scarlet
        Got her in '11
        Ready for the twisties!
        81H (previously CPMaynard's)
        Hugo
        Cold weather ride
          When I first got my bike, it had no key, so I did the same thing. Took the ignition switch off and took it to the local dealer. I read the numbers off the bottom of the switch and he cut a new key from them. The first key he cut didn't work, so he cut a second one with the same numbers and it worked. It looks different from the OEM keys (much longer) but has the same bumps and ridges as the original.
