I think I know what this means, but if anyone has any other ideas let me know. White smoke at start for about 10 seconds out of the left exhaust. Plugs look a little black - maybe a trace of oil. Not the normal tan. I will be doing a compression check to see what it shows. Anything else I can be doing to determine cause of smoke? Thanks.
White smoke at start?
Usually if it is only at start up and goes away after a few seconds then it means the valve seals are leaking.Nathan
Originally posted by Redshirt View PostQuestion on same topic: Could this be associated with flooded carbs on kickstand-leaning side?Nathan
I had the same prob, so I took out all spark plugs, added a couple of drops of transmission fluid in each cylander, and waited a few minutes. Then hit the starter button a couple times to blow out any excess fluid before replacing my spark plugs. (Dont add much because it can sieze up the motor). It really white smoked upon start up and blew white smoke for awhile but eventualy stopped and I have not had that problem since. Not sure why or how this helped but it did. There are a lot smarter people with a lot more expirience on here than I have though, so you may want to ask around before doing this.Brian
1980 xs1100 Special - Work in progress
Originally posted by tri650 View PostHow do I determine if the valve seals are leaking? Could it also be rings?
Only way to really know is to pull the head and replace them and see if the smoke goes away....Nathan
Originally posted by tri650 View PostThat is more the situation - it blows smoke for about 10 seonds and then runs clear. Would a compression test give me more direction on the rings? Plugs - what should I be looking for?Nathan
White smoke at start can be excess fuel; if raw fuel is getting into the cylinder that's what you'll see. Valve seals/guides will also be white, but with a blueish tint, and you'll usually get much less volume of smoke. If you're laying down a good-sized cloud, look at the carbs.Fast, Cheap, Reliable... Pick any two
If it's the seals it CAN be because they dried out from sitting or it can be because they are damaged. If they are damaged there is nothing you can do short of replacement. If they are dried out, there are seal revitalizer products out there these days that WORK.The ones I have found that work are all thicker more viscous products, which when I looked up what they contain is basically the same stuff that motor oils contain to keep the seals from drying out in the first place (many people don't realize that the oil in the engine is in part designed to keep the seals from drying out and shrinking, and and engine sitting with no oil getting to the seals, that's one of the things that goes bad). I put the stuff in ANY engine that I put into service that's been sitting for more than about a year, and on engines that were exhibiting leaking seal problems, in most cases it has stopped the leakage (the cases where it didn't and I tore into the leaking area I found damaged seals, which these products cannot do anything for and don't claim to be able to) within a pretty short time.
With these engines I typically use about half a dose, based on crankcase capacity vs automotive capacity, and generally it's a one time treatment, if that doesn't do it, IMHO you need to go in and fix the problem anyways cause they are too dry for this to work. Also, I've never had it cause any problems with the clutch on any wet clutch system I've used these products on, they are NOT friction modifiers.Cy
To answer a few questions:
Bike runs great. No problems starting or running. When it sat for a week or more I got a really big cloud of white smoke for about 5 seonds - then less smoke and then it was clean.
What would be wrong with the carbs for them to flood the cylinder - stuck float? What else would I be looking for in the carbs?_____________________
78 XS1100 - mainly stock
Originally posted by tri650 View Post..When it sat for a week or more I got a really big cloud of white smoke for about 5 seonds - then less smoke and then it was clean.Fast, Cheap, Reliable... Pick any two
The white smoke is not smoke.. It's probably water vapor in the exhaust!78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
2006 Roadstar Warrior
