exhaust gaskets
  • exhaust gaskets
    Good evening, I have the original exhausts and am wondering if anyone knows if other bikes exhausts gaskets would be compatable with ours. I need to replace the three big copper/brass gaskets at the header and cross over connections.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Hi Mack,
    not the cylinder head gaskets but the crush sleeves?
    I replaced those last year, bought them at my local Yamaha dealer. Not cheap but they can still get them.
      I'll try
      I'll check but I was on the yamaha site and they showed up with a large red triangle. I figured that meant they were no longer available. Would the 650 use the same one?
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
        Seriously doubt those gaskets have been discontinued.............too many scoots use the same gaskets. 3JJ-14653-00 is the lower crush sleeves for the two head pipes and the crossover. 4BE-14613-00 is the head to header gaskets. That's taken right off the packaged ones I have. Heck, even the kickstand rubber bumpers are still available................
          Mack, that red triangle means they're still available but the part # has been superceded with a new #...
            The old ones were made with a copper jacket, inside and out, with a fiber liner between them. The new ones are a fiber tube, which means that when you pull them apart, if there is any rust or corrosion in the joint, it tends to tear the fiber up, causing a larger gap when reassembled, and possible leakage. And they are rather expensive.
            I have an old muffler from a Honda that has the original style gasket, but I haven't found out from the number what it came off of. You might take your old gasket to a Honda dealer and see if any of the parts guys can tell by looking at it if they have them. Sadly, those kind of parts men seem to be a dying breed. CZ
              Found some
              I found some, from Yamaha. Go figure.
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
                Just out of curiosity, how much did they cost, each?
                Seems like I paid close to 20 dollars for one, a year ago.
                And it was one from a Yamaha dealer, and one of the all fiber ones. No joy CZ
                  cost
                  It came to $14 can all in.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                    Do they sell mail order? CZ
