Tube on carb # 2
  • mmaddix
    • Jul 2011
    • 232
    • Beaufort, SC
    Tube on carb # 2
    I just noticed that there is a tube coming off off the #2 carb just outboard of the idle mixture screw for the #2 carb. What is this for. Is there supposed to be a tube connecting it to where the vacuum cap is on the boot for the #2 carb.
    Thanks everybody,
    Mark
    USMC 2005 - Present
    79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
    78 XS1100E - Rebuilt And Sold I SHOULD OF KEPT IT!!!
    Mark
    Hi Mark,
    the connection from the #2 carb body is for the vacuum tube that connects to the ignition vacuum advance. The vacuum tube should enter the left rear crankcase casting and hook up inside. You can see how it should connect if you take the ignition cover off.
    The carb boot connections are for balancing the carbs. They are normally capped off except one of them works the vacuum gas taps unless a PO has disabled that feature and converted the taps to manual operation.
      They are normally capped off except one of them works the vacuum gas taps unless a PO has disabled that feature.
      #2&#3 intake boot brass nipple is for left and right vacuum petcock if a Standard.
        Originally posted by motoman
        #2 intake boot brass nipple is for left and right vacuum petcock if a Standard.
        Hi Mark,
        moto's right, two intake boot vacuum connectors work two vacuum gas taps on a Standard. The Special uses one intake boot vacuum connector to work the octopus. (centralized vacuum operated fuel control valve)
        • mmaddix
          • Jul 2011
          • 232
          • Beaufort, SC
          Thanks everybody I see where it is supposed to go I am going to get some hose from the auto part store.
          USMC 2005 - Present
