jet needle slides
  • mack
    • 2411
    • Ontario, Canada
    jet needle slides
    anyone ever put lithium grease on their slides, or, is this just not required?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Lithium grease tends to get gummy after awhile. I personally leave them dry.
      What Nate said.....
      • cywelchjr
        XS-XJ Super Guru(Deceased)
        • 4450
        • Sacramento, CA
        If I do anything with mine, I put a little silicone spray on them, but I generally don't do anything with them, they get just enough from the fuel and from the blow by from the crankcase to keep them moving freely without me having to do anything.
        • James England
          • 3039
          • North of England
          Absolutely no way would I use anything other than a light spray of silicon spray. Proper throttle operation depends on the carb diaphragms acting asap on the slides. If you introduce resistance like grease, you'll end up trying to blip your throttle and find nothing happens.
          • brcree
            • Mar 2010
            • 388
            • S.C.
            slides...
            Has anyone used powdered graphite?
            At this time:
            1985 Goldwing Innr.
            1976 cb 750 cafe racer
            2007 vtx 1300
            81 sx 1100 s h
            81 sx 400 special
            • cywelchjr
              • 4450
              • Sacramento, CA
              I see the wink. I think that powdered graphite wouldn't stick around long enough to do anything, and if it did, I think it would be more likely to turn into mud on the outside of the slides.
              • jeffro1954
                • Aug 2009
                • 72
                • Minnesota
                sewing machine oil.
                1978 XS1100
                1979 Honda Goldwing
                • James England
                  • 3039
                  • North of England
                  No oil. Just leave them alone. They were never designed to be lubricated.
                  • cywelchjr
                    • 4450
                    • Sacramento, CA
                    I mentioned spray silicone as the only lube I would use, but normally the only thing I do to them is clean them up good to make sure there is nothing foreign on them so they move freely. There IS some sort of coating on them, and the slight oiliness of the gas and such itself provides all of the slip they need.
                    There are one of the closest fits I've ever seen, which is why you have to be very careful about damaging them, but if you damage them, no amount of lube is going to fix that, and if they are not damaged, they will move fine. But all it takes to make them hang up is a thin film of varnish from the gasoline in the carbs, it's that close of a tolerance, so just about anything you try and put on them is going to get in the way of them working properly.
                      If you're having issues with the slides being a bit 'sticky' even after cleaning, I've lightly 'polished' the slides and their bores with 0000 steel wool and that's done the trick. This needs to be done while the carbs are off/apart, as you don't want the steel particles getting inside the motor...
                      • mack
                        • 2411
                        • Ontario, Canada
                        Good
                        That's good cuz I haven't been putting anything on em with the 79 carbs, working on 80/81 's now and was wondering if I'd been negligent. I must say though that I much prefer the 78/79 carb's. They have more tuning options and float valve set up is better. These 80/81 carbs seem a bit mickey mouse to me. BTW, the silver round disc I gather is to be inserted over the idle screw passages. Isn't there a better way, like a rubber plug you could get out more easily in the future?
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
                          I am planning on shoving a rubber plug in mine, so something else haven't decided. I am not putting one of.those brass discs back over it though.
                          • cywelchjr
                            • 4450
                            • Sacramento, CA
                            Yeah, the plug for the hybrid carbs low speed jet is just the right size for that mixture screw tunnel, and you can get them from MikesXS.
                            • mack
                              • 2411
                              • Ontario, Canada
                              plugs
                              Cy you got a number for them, is that the passage plugs on mikes XS?
                              mack
                              HERMES
                              original owner
                              81 XS 1100 LH MNS
                              SPICA
                              78 XS 11E
                              IOTA
                              613-398-6186
