Here's one I don't understand on my 78E (Organ Donor). I had gone through the carbs, and reinstalled them. Did the 'Earball' sync of the carbs, and it idled and ran great. Real quick acceleration! Better than my 80SG. I let it warm up at idle, and after a few hard twists on the throttle, it died. I checked power at the coils, had it there, so I pulled a spark plug, reconnected the plug wire, and checked for spark. No spark. Checked the wires to the pick up coils first. BTDT. No broken wires. Made sure the connector was making good contact with the CDI module. Started probing the connectors at the CDI module, using a volt meter, and at the connector for the pick up coils (PUC) I found that when I had the probe touching the wire (white w/ green tracer) leading to the PUC's, and cranked it, it would run, and when I removed the probe, it died. I had .5 volts leading to the PUC's. I was very lightly touching the wires, no pressure involved. Did this several times, same result. Removed the cover to CDI and started probing the solder connections for the terminals for the PUC connector. Same result. Would run when the probe was touching the solder joint, and die when probe was removed. Then to my surprize, one time I did that, and when the probe was removed, it kept running. I shut it down, and tried to restart, it lit right off. Tried it several times and each time it worked properly. Is there any possibility that the meter was supplying the ground for the TCI? Why would it take a constant ground on one of the wires for the PUC's make it run, when that ciucuit gets interrupted by the PUC's?
Anybody ever run into this problem before? What was your finding?
