Help with Exhaust
  • Aches n Pains
    • 349
    • Reston, Va.
    Help with Exhaust
    Need help with a set of exhausts for the new project. PO had cut the end out of the original pipes. I have the set shown below in my inventory. Problem is getting out the inserts from a previous life somewhere.
    Both the headers and the pipes are 1.5" ID. Therefore, I will need to use a 1.5" OD insert to join the pipes.
    Problem is that I can't get the old insert out. Tried PB blaster for weeks. Tried lots of heat. Enlarged the slots in the pipes. Even welded a piece across the insert and beat on it with a rubber mallet till it broke off.
    Any suggestions would be hugely appreciated.
    Aches n Pains
    1995 KZ100P
    Pods, jets, pipes, cam adjuster, oil cooler
    1977 Ironhead - custom build
    Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
    Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
    No idea.........but a decent set of Jardines with the cross-over............
    • justme1100
      • Jul 2008
      • 243
      • Eagle, WI
      Chip away at it
      My suggestion would be to use a dremel tool with a metal cutting disk to the inside, just don't cut all the way through, until it comes loose or you cut enough away to insert new connection. Good luck.
      Just ME and my 82 XJ 1100. Mac 4>1-2 1/2" open baffle shotgun, no octy, K&N pod filters, LED tail/brake light & directionals, 750 FD mod, Ear Cannon air horn, modified bars and dash. "Motorcyclists are all bound together by a brotherhood tie through their love of the sport, and what difference does it make what machine he rides as long as he belongs to the clan." Walter Davidson, Dec. 1920 edition of Harley-Davidson Enthusiast Magazine http://s851.photobucket.com/albums/ab78/justme1100/
      • ManagerMike
        • Mar 2010
        • 445
        • S.E. Michigan
        Assuming you are trying to remove the inserts from the pipes in the picture, that is a basic skill learned early on for anyone trained in automotive exhaust repair. Using a cutting torch, one cuts the insert
        from the outer pipe so that it comes out in two pieces. I still call them "muffler bearings" as they resemble rod or main bearings in a standard cage engine.
        The trouble with using the torch method in your situation is the discoloration of the chrome that would result. Therefore I suggest a reciprocating saw with an appropriate blade to cut the insert through lenghtwise at two opposing locations, then remove the two resulting 'muffler bearings'.
        Do you follow?
        '78 E "Stormbringer"
          Originally posted by Aches n Pains
          - - - Problem is that I can't get the old insert out. Tried PB blaster for weeks. Tried lots of heat. Enlarged the slots in the pipes. Even welded a piece across the insert and beat on it with a rubber mallet till it broke off. - - -
          Hi Doug,
          try this:- weld a 1/2" nut to a fat washer.
          Grind the washer OD so it fits the end of the insert and weld it in place.
          Thread your slide hammer into the nut and go at it!
          But FIRST CAREFULLY CHECK that the PO didn't plug weld that insert in there.
          • Aches n Pains
            • 349
            • Reston, Va.
            Good suggestions. Will try the reciprocating saw first and then the welded job. Also a good tip to be sure there isn't a weld inside the pipe.
            Thanks,
            Doug
            1995 KZ100P
