Elinminate sqeaky brakes.
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    As part my rebuild I instaled new EBS copper sintered brake pads on my G.
    After a while they started squeaking, no - more like squealing like pigs!!
    Every time I pulled up to a light, I got stares. And when riding with others.... the comments were always forthcoming.
    I sanded the rotors to no avail. So I tried a trick I used to employ on my VWs and Volvos.
    I removed the calipers and pads, sanded the rotors with 80 grit, and then I groved the pads. I groved the pads by putting them in a vice, lengthwise, then using a hacksaw I cut a perpendicular grove leaving aout 1/8" of backing. This creates two +/- 1.25" X 1.25" pads on the metal backing.
    I then applied some of that 'special' brakepad grease on the backs of the pads, re-installed them, and re-assembled the calipers.
    Haven't heard a squeak or squeal since.
    Hope this helps if you're experiencing the same issue.
    Last edited by Cobia; 08-23-2011, 08:39 PM. Reason: Misspelled "Eliminate" in the title
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
  • TADracer
    • May 2006
    • 1417
    • Kenner, Louisiana USA
    I had a similar issue on the front with some Vesrah semi-metallic pads and I did a similar thing except I cut a very shallow X across the pads. Squeal went away and I still have the pads installed (though most of the X is now worn away).
    Not sure why this worked other than guessing that it helped get some of the brake dust out from between the pad and rotor.
    Mike Giroir
    79 XS-1100 Special
    • Cobia
      • Jul 2007
      • 1587
      I think that's the key to quieting them down... getting that dust out of there.
      Kerker 4 - 1
      850 Rear End Mod
      Automatic CCT
      '82 XJ1100 (Sold)
      • Tat2demon
        • Jun 2012
        • 718
        • Sioux Falls, South Dakota
        I know this is an old post but I wanted to say thanks.
        After reading this the other day I used my dremel and a cutting disk and cut a line in each of my front pads.
        Went from embarrassing to silent.
        Nate
        78 XS11 "Matilda" 2H7 000364
        K+N Air Filter
        88 Voyager XII
        81 XJ650 Maxim
          This looks like a nice little tech tip....
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            Sweet, I cant wait to try this on my front pads as they have been giving me back talk lately. I will report out when I'm finished.
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            '84 Chevy K-10 "Big Blue"
            • DAVINCI
              • Jan 2011
              • 1048
              • Cedar Mountain, NC
              chamfering the leading edge of the pads works, too.
                Cant remember what brand pads it was that I bought (thought it was EBC) but they came with the front and rear edge chamfered and a groove cut down the center already.
                • Tat2demon
                  • Jun 2012
                  • 718
                  Yeah EBC come in grooved and non-grooved. Pyramid parts look to be non-grooved only.
                  Bike Master pads are grooved.
                  I was very surprised at how easy the pads cut. I always thought they were much harder than that.
                  Nate
                  K+N Air Filter
                  88 Voyager XII
                  81 XJ650 Maxim
