Suitable for Tubless Tires Poll
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    I'm interested in knowing what everyone is running. Mileage on said set up and if any incidents were experianced
    Hopefully none.
    If you are running one set up in front and a different one in the rear you can choose two.
    Please post how you are set up.
    Thanks in advance.
    Rick
    57
    Tube type rim, tubless tire and no tube.
    7.02%
    4
    Tube type rim, tubless tire, and a tube.
    12.28%
    7
    Suitable for tubless rim, and tubless tire.
    73.68%
    42
    Suitable for tubless rim, tubless tire and tube.
    7.02%
    4
    650SF
    XS1100SG Project bike
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    Stock 80G wheels, with tubeless rims and tubeless tires on them. Been that way for the 25,000 miles I've had the bike, which = 2 front tire changes and 3 rear changes (both front and rear not too long after I bought the bike and then 2 to 1 ratio afterwards and about 9k on the rears so far).
      Stock 81H, has had bout every manufacturer's cheap and pricey tire under the sun on it at one time or another. Changes are approx. a 2to1 tatio. No tire incidents ever. 80,800 on the clock.
        I'm running stock SG tubless rims and tubless tires. Was runnig cheap Shinkos all around but wasn't getting good miles out of those on the rear. Anywhere from 3000 to 6000, fronts not so bad. Got a Dunlop E3 on the rear now and it's doing real well. Got about 5000 on it so far and it's barely showing any wear.
        The only incidents I've had were the rear went flat on me twice on the way to the Lost Rally last year. Both times I was able to plug it and get down the road within a half hour. That would be tough to do with a tube.
          • 8962
          I have several rims front and back, both tube type and tubeless type. I run them all with tubeless tires, no tubes installed. I balance them with real weights, not dynabeads, .
            Ha ha ha..........+1
            • cywelchjr
              • 4450
              • Sacramento, CA
              I've seen people swear by and swear at dynabeads. They are kinda like oil. Some people love them, some hate them. For some people they work really well, for others not at all. One drawback, if you get a hole right in the center of the tread with dynabeads you WILL have to remove them/change out the tire, cause the repair will interfere with them working. I've heard many stories of increased tire life, particularly on the front wheel, and of them being of particular use on hard to balance wheels. But again, they are a VERY personal thing, but I'm getting tired of the inability of anybody to properly balance my rear tire. I'm about to put them in it just to eliminate that problem, and if that works, then I'll try the front, and see how it goes (hey, if I don't like them I can always take them out).
                • 8962
                Sorry, I shouldn't have mentioned dynabeads and got this thread sidetracked.
                • Dr Mac
                  • Jul 2011
                  • 5
                  • kansas city Mo area
                  I'am not sure . I have two bikes with 17 inch wheels one with a 16 ( that is a bare wheel that needs mounted ) that is now painted with no valve stem .
                  • dbeardslee
                    • 4385
                    • Maineville, OH
                    I've got tube type rims with rim locks on the rear so I run 'em with tubes. Hard to find a tire that isn't tubeless anymore, so the tires themselves are tube type, but I haven't had any trouble out of them. I also run a 110 in the front, which is about as fat as it'll take, and I like it a lot.
                    I wouldn't want to get a flat out on the road with the tubes, though. It's not something you're going to fix on the side of the road. Especially in the rear with those rim locks.
                      You can run a tubeless tire on that rear rim Doug, Just remove the bead locks (unnecessary anyway) and plug those holes with a short bolt and nut w/a couple flat washers and rubber washers. The casting on that rim is the same as the tubeless rim just a couple extra holes drilled in it. The front rim is a little different and shouldn't be used tubeless. All XS's 750 - 1100 that were tubeless fronts used the same front rim so it should be really easy to find one of those.
                      I believe the only Standard that CAME with a tubeless rear was the 81 Venturer.
                      • dbeardslee
                        • 4385
                        • Maineville, OH
                        I actually kind of like the rim locks. They're supposed to keep the tire on the rim if it goes flat while it's rolling so it doesn't get jammed up and potentially lock up the rear wheel. Is it likely to happen? Probably not, but I like 'em there anyway.
                        The guy that changes my tires for me can do a rim lock wheel faster than I can say it, but some shops balk at rim locks. And it's probably just my imagination, but I'd swear a tire with a tube in it holds air better than one without.
                        The real downside is if you get a nail in it. I wouldn't run a plugged motorcycle tire very far, but I would plug one to get me someplace where I could have it patched or replaced. That's just not an option with tubes.
                        But it just hasn't been a problem for me, and you know what they say - if it ain't broke...
                          Actually the bead lock was put there to keep the tire from spinning in the rim. Yamaha decided it was unnecessary in 79 when they put out the Special. Nobody ever spun one.
                          I've had the rear go down at highway speeds several times. Tire stayed on the rim fine. Plugged it, aired it up and kept going.
                          Happened twice on the trip to the Lost Rally in 2010.
                            twice in one trip? That is incredible bad luck! I once tried to get the rear tire off the rim of one of my 78's I finally gave up. There is no need for rim locks on the back tire.
                              This reminds me of an experience I had while I was serving in JAPAN in the early 80's!
                              I was still riding my Yamaha TX500A that I had brought with me early in my tour. I had ridden out into the country for some sightseeing, and then it happened, I got a flat on the rear, and it was a tubed tire. There wasn't a motorcycle shop around, but I was able to roll/push up to a bicycle shop!
                              I didn't have any tools with me(ignorant youth) and I thought the Bicycle shop would pull the tire/rim off the bike(chain drive). But I was surprised to see them getting the inner tube..finding the hole because I think there was a nail or screw....they then pulled the inner tube sideways out from between the tire and rim right there ON THE BIKE. They patched it, and then were able to put it back in, air it up and I was able to get back to the base!
                              So...yeah, flat tires on the road are a real bummer.
