New to the 1100 With Questions
  • va_blue_stang
    • Aug 2011
    • 97
    • Bluford Il 62814
    I have new question, what a surprise. Is they're an oil additive that is safe for these engines that will help with a stuck ring? I'm Getting a little oil on the plug in the #2 cylinder and it's not firing like it should?
    82 XJ1100
    Very Little that is factory left.
    Large mix of XJ/XS parts
      • 9981
      Most oil additives don't play well with our wet clutches. The best thing for a stuck ring, if that's what it is, is run the engine. With several heat soaks and the vibration it should loosen up.
      If it is a stuck ring it should show up in a compression test otherwise it's probably a leaky valve seal.
        Yup, buy some extra plugs and carry the socket and rachet with you and just swap out plugs every so often to keep the cylinder running as much as possible.
        Then to clean the could up plugs, take a propane torch and heat the grounding strap on the plug and the electrodes are with the torch till the black crap turns white and then hit it with a wore brush to clean it all off and you are good to use them again.
        • va_blue_stang
          • Aug 2011
          • 97
          • Bluford Il 62814
          ok guys thanks for all the help
          82 XJ1100
          • va_blue_stang
            • Aug 2011
            • 97
            • Bluford Il 62814
            Quick question before i decide to place an order. Will the caliper rebuild kits and master cylinder kits on mikesxs site work on our 1100's?
            82 XJ1100
              Yes; if you order the right ones; 29-0016 calipers, 08-0204 master cylinder.
              Interesting, they're now showing XS1100 applications....
