XS11 Special Tank Capacity?
  • TucmanXJ
    • 108
    • The Old Pueblo, AZ
    XS11 Special's fuel tank capacity in US gallons.
    Searched for answer = not yet found.
    Thanks for the assist.
    Rob
    79 XS11 Standard F stock "Big N Blue"
    Capacity is 3.8 US gal.
    • b.walker5
      • Feb 2009
      • 1745
      • Invercargill, New Zealand
      "Not Enough"!!!
      Hey, Just a thought, but has anyone thought of adopting the Virago idea of using a secondary tank and fuel pump?? Didnt know they did that until today and thought "what a good idea". Now, to find somewhere to mount a secondary tank.....
      • Nubian
        • Apr 2011
        • 467
        • The Big East
        Originally posted by b.walker5
        "Not Enough"!!!
        I think I read somewhere on this forum, that you can mount a standard tank onto a special with little modification. Not sure though. I have also seen I believe it was a Maxim tank put on a special, and their capacity is up there round 6 gals. just like the standard.
        BAMN!
        '81 XS1100H "Brutus"
          I think I read somewhere on this forum, that you can mount a standard tank onto a special with little modification. Not sure though/////////////Yup, 'plug&play for the tank......fuel supply from petcocks changed by eliminating the 'octy' using 2&3 vacuum ports to the vacuum petcocks.....seats not an issue as front cushion portion just rides up higher against the tank.
          • KA1J
            • 664
            • Groton, CT
            Although you were given the US gallons you asked about, here's a great site that gives a lot of nifty info on most all of the different bikes out there by make, series & year introduced: http://www.motorcyclespecs.co.za/mod...sf_special.htm
