Popping On #4 Carb
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    Popping On #4 Carb
    I cannot figure this out.
    I synced the carbs, Timing is good.
    Yesterday I took my ride out for a test ride all was good.
    Today took my ride out and now I am getting a popping on #4 carb. Checked the sync, noticed that the sync is good until the popping. I the loose all vacuum in #4 carb.
    I put up a video. The popping is almost rhythmic.
    Any ideas?
    Thanks again all,
    Ozz
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
    Have you checked your valve adjustment? A too-tight intake can cause this...
    • heatmanal
      • Aug 2007
      • 17
      • Martinsville Indiana
      try turning your pilot screws out 1/4 turn at a time.I had this problem on my xj,running to lean.
      XJ1100J;
      Hooker 4 Into 1 with Supper Trapp baffles,12discs
      K&N Pods
      125 Mains
      50 Pilot Jets
      Metzler Marathon tires
      180 pilot air jets
      Barnet clutch, Heavy duty springs
      Dyno 82 hp
        • 8797
        Ozz, check the vac caps and stems on carb boots. The stems come loose and the caps could leak causing a vac leak. Engine side gasket leak maybe? Popping is a lean condition, plugged fuel filter? How does it ride that way?
        • MrOzz
          • Aug 2008
          • 782
          • Massachusetts
          I did the valve adjustment last fall. I will double check it once it has cooled overnight. Is this something that can happen all of a sudden? Fine one day, then not the next?
          I just did adjust them with a colotune this week before I adjusted the timing. All seemed good then.
          I was thinking the same phil. I did the propane test. I did not get any change in the rpms. Carb boots look good. I did replace the vacuum caps thinking they might be the cause. I will have to double check on the gasket. Fuel filters and carbs were just cleaned a week ago, fuel does look to be flowing through my fuel lines, Clear fuel lines, no octy.
          As the ride goes, all was fine yesterday. Today loss of acceleration in low to mid throttle. Then fine until the popping, now no matter what #4 keeps popping and the bike runs like crap from low to wide open throttle.
          When I put my carb synchronizer on carbs 1,2,3,4 were even at 23cmHg, until the pop on #4. #4 would drop to 8cmHg, but thats the lowest # on the scale of my carbtune.
          At one point I removed the vacuum cap on the #4 carb boot and thought I saw a little flame. I could not get it to happen again.
          Thanks guys for your help with this.
          1980 XS 1100SG
          Pod Filters
          DynoJet Kit
          T.C.'s Fuse Block
          V-Max Auto CCT
          • Winterhawk
            • Jun 2004
            • 684
            • Missouri
            Check and see if your carb sync tube didn't get pushed down into the intake manifold. This happened to me and I fought this problem for over a year. Runs great now and all I did when removing the carbs for the 20th time was look into the carb boot and see and feel the tube sticking down into the intake manifold.
            • MrOzz
              • Aug 2008
              • 782
              • Massachusetts
              OK I am 1 step closer. After double checking everything again. Setting up my color tune everything was running fine. After a little bit #4 starts to pop again.
              I noticed that I had very little fuel in the fuel line. Removed the filter. Same issue. If I disconnect the fuel line from the carbs fuel flows with no problems.
              Where in the carbs do you think this problem lays? I am thinking in the float needle seat?
              1980 XS 1100SG
              Pod Filters
              DynoJet Kit
              T.C.'s Fuse Block
              V-Max Auto CCT
                • 8797
                I would guess in the pilot circuit. Maybe a loose air jet at the back of the carb? Could try a dose of Seafoam first.
                • MrOzz
                  • Aug 2008
                  • 782
                  • Massachusetts
                  I will check that air jet. I have pulled the carbs and giving them a cleaning, again. I this will be the 5th time in a week the carbs will be cleaned out.
                  1980 XS 1100SG
                  Pod Filters
                  DynoJet Kit
                  T.C.'s Fuse Block
                  V-Max Auto CCT
                    Hey Ozz,
                    From what you described, that sounds like the culprit, a sticking non-dropping float so the valve isn't opening to allow enough fuel flow to keep the bowl filled. You could do an experiment, run it till it starts popping, then quickly shut off the fuel, and the bike, and then remove the float bowl and ses if there's much fuel in there? If there isn't much, then it's a supply issue, and could be a sticking float or a sticking needle valve?
                    • Toolmaker Tim
                      • 671
                      • South Bend, Indiana
                      Did you check your bowl vent? if that isn't working it might lean out hte carb because the bowl can't keep up with demand. Just a thought.
                      1979XS1100SF
                      K&N's and drilled airbox
                      Jardine 4in1
                      Dunlop Elite 3's
                      JBM slide diaphragms
                      142.5 main jets
                      45 pilot jets
                      T.C.'s fusebox & SOFA
                      750/850 FD mod.
                      XV 920 Needle Mod.
                      Venture Cam Chain Tensioner
                      • MrOzz
                        • Aug 2008
                        • 782
                        • Massachusetts
                        Hey Ozz,
                        Sounds like a good idea. I will compare the fuel in the bowls.
                        Originally posted by Toolmaker Tim
                        Did you check your bowl vent? if that isn't working it might lean out the carb because the bowl can't keep up with demand. Just a thought.
                        I was thinking that also. I cleaned everything so far the carbs were nice and clean.
                        I am having a brain fart. When you measure the float level that is with the gasket removed?
                        1980 XS 1100SG
                        Pod Filters
                        DynoJet Kit
                        T.C.'s Fuse Block
                        V-Max Auto CCT
                          • 8797
                          That is correct.
                            Yep, Gasket removed for float level. You may also check the fuel T itself for any debris or the screen on the float valve.
                            I would also think this could be the bowl vent. I am sure you already have, but make sure you spray cleaner through that vent passage.
                            • MrOzz
                              • Aug 2008
                              • 782
                              • Massachusetts
                              That is correct.
                              Thanks guys. Glad I have WiFi. Keep my laptop next to me while working. Makes life a little easier.
                              So far, the screens were clean. The vent passage clean also.
                              1980 XS 1100SG
                              Pod Filters
                              DynoJet Kit
                              T.C.'s Fuse Block
                              V-Max Auto CCT
