As has been stated, bent valve means it can't close which would give you zero for compression.
You have to remember that this is rough metal to rough metal contact surface (with holes in it too!) The two surfaces over time smooth out and seal better against each other. YOU WILL HAVE low compression for awhile, that's how it works. I put new rings in over the winter and still havent checked compression.
The majority of the seating of the rings happens in the first 50 or so miles but even with that it isn't done till more like 1000 miles. So I would say get it together and get her broken in. Have you ever broken an engine in?
