Are fork caps interchangeable? (Standard to Special)
  • 11Rider
    • Aug 2010
    • 331
    Hi guys, I'm getting the Progressive springs for my forks ('79 Special) and want to get the plain caps for my forks. Besides supposedly not needing air pressure with the new springs I am missing the valves that go on my caps. Just wondering if caps from a standard would fit my Special.
    '79 XS11 Special, fork gaiters, Uni pods, 45 pilots, 140 mains, ditched the octy, solo seat, T kat fork brace
    Purrs like a kitten, runs like a scalded cat
    In a short answer, No, they have different threads. The air valves you are missing can be permanently sealed off with a bolt and teflon tape or RTV.
      This wasn't your question...but also worth noting, you can't put 78 caps on an 81 standard (and probably an 80). They look to be the right diameter, but no-go.
      • 11Rider
        • Aug 2010
        • 331
        Wow, I was expecting to hear a verification of my suspicion that they WOULD be interchangeable, but I'm glad I asked. I'm watching some caps on ebay for 25bucks a piece so I must be careful. Thank you so much.
          Yep Skids you are right. AFAIK, there are 3 different caps. 79-79 Standard with preload adjustment, 79-81 Special with Schrader valve, 80-81 Standard with Schrader valve. None will interchange with each other.
            Trying to wrap my mind around why you would want to change from air adjustable (infinite) to standard (3 settings)
            • 11Rider
              • Aug 2010
              • 331
              In both Specials I've owned I've never added air to the forks anyway. I read on this forum that with the new Progressive springs it's even less relevent. On the other hand if I could find the air valves at a decent price I'd just put them in but I've only seen one on ebay and it was 35 bucks. I don't want to put out 70 bucks plus shipping for something I don't need.
                I like the early standard fork settings. No worries about air caps. Manual preload works. I think airforks were a "high tech" fad.
                • CaptonZap
                  • Jun 2010
                  • 1748
                  • Denver
                  Take two 1/8 inch pipe plugs and put them into the holes that the air fillers went into.
                  If you want to be fancy, you can get them in blue anodized aluminum, down at the car speed shop.
                  All you need to do is keep the dirt out of the fork tubes.
                  Po boy say "Aw got sum bubba gum?"
                  CZ
