On my 82 XJ1100, I found yesterday that my charging system is not working. I parked at the end of my driveway to swap bikes in the garage and went back to start it and it wouldn't start. The battery was mostly dead. I dropped it on the charger for a bit and the bike fired right up.
The quickest thing I could do at the time was check voltage when revving and it isn't moving from the ~12v it starts at.
I'm not too concerned about the charging because I have not done much to troubleshoot at this point, so it could simply be a broken wire from the stator that I previously soldered or a bad job with a connect I added to the regulator recently.
For the hell of it, I pulled the stator cover and took a look at the rotor, stator and brushes. Unfortunately I slipped putting the stator back in the cover and broke one of the brushes (already ordered new ones), so I can't really check much until I get new brushes.
This morning I went to the garage to hook up the float charger and happened to bump my brake lever slipping past the bike in the dark garage and the brake light lit up
Ignition is off and the kill switch was off.
I tried the rear brake and no brake light. Is this normal on this bike? Nothing else works with the ignition off. I could have hooked something up wrong when I swapped my cluster, but I'm just letting her sit until the brushes get here. Any thoughts?
