Been working on Sica's head for the last couple days and have a couple questions. First, are the oil return gallery's larger at the exhaust side because the motor is tilted in that direction and the cam lobs throw in that direction?
Second pertains to the bearing surfaces under the caps. The PO didn't believe in changing oil or filters I guess. The bearing surfaces, (and the cams) are all surated with grooves. Looks like metal filings were drawn up into the cams from the sump. I'm not too happy about this as the bike has less than 10 k on it. That's why I bought it. At least the grooves are all in line with the rotation. How much is too much. Also as a side issue. The last guy to shim this went the wrong way with #3 & #4 exhausts. Not sure how many miles were put on with it hammering like that, but I'd say a fair amount. A quick check indicates those two need to be upped to 305 when the other two are 285. My question is can the valve seats be replaced?
