Nice sound
  • caman
    • Dec 2010
    • 9
    Nice sound
    So on my way to work last night I got into the throttle in 5th and heard a loud bang as if I had thrown a rod. After that I hear a clicking sound and it doesnt want to stay in or even go above 5th any more. does anyone have an idea. I have a ride sunday and I want to go.
    Not to be picky, but I assume you mean it will not go into 5th or stay there.
    Does it run fine in all other gears still? Idles fine? Other than perhaps this clicking noise that is.
    If you pull the shift cover on the left side and look at the shift drum it has a "cover" on it that holds in the pins that the shift pawl grabs to turn the drum and shift gears. From time to time, folks have had an issue of the pin that lets it shift into 5th gear falls out. If that happened to you, you might here the pin rattling around and getting tossed about in the engine until it hopefully fell into the oil pan without hurting anything. Look to see if it is indeed missing, and if it is, you may need to drop the tranny/oil pan to see if it is laying in there.
    Now that would not necessarily explain the bang, unless it came out. got into the gears, and you heard it get tossed violently into the case?
    • caman
      • Dec 2010
      • 9
      Ive had that pin fall out already and I put it back in. The problem is 3rd. it will go in then after a little bit it will either pop out or sometimes not even go in. I did have a wineing sound for a while and now it seems to have gone away. i hope I didnt f the tranny up to bad.
        So it idles fine, runs fine in neutral, will shift fine into 1st and 2nd, but will not or very difficult shift into 3rd, and will not go above 3rd?
        Have you tried shifting with the engine off, sittign on the centerstand, roll the back tire a little between each shift and see if it goes in then?
        • caman
          • Dec 2010
          • 9
          It shifted fine in all gears but every now and then it wouldnt **** above 3rd. Update the trans let go now she is jammed in 2 and locked up. Well I dont know when or if I can fix it now. Thanks for the ideas though.
            I would pull the tranny pan off and see what you see in there, as well as the shift cover on the left side. Something is off somewhere. Try to move the rear wheel forward and back while trying to shift, it might let it come free of 2nd.
            • caman
              • Dec 2010
              • 9
              Ive tried that while it was being pushed back to my girlfriends and she would not let go. I cant tear into it tell saturday when Im not working.
                • 9980
                It sounds like you and brharris27370 are having pretty much the same issue.
                Y'all might want to put your heads together.
