Thinking of adding driving lights to my XJ1100
Theodore Roosevelt -
I will take some, promise. It turned suddenly cold here so I'm waiting for the Indian summer effect.
However, take a look at these, and click the middle tab, "Detailed Description:"
http://stores.advmonster.com/-strse-...off/Detail.bokLast edited by LCS249; 10-08-2011, 02:14 PM.1982 XJ1100J Maxim
2000 BMW R1200C
“We go to heaven for the climate, hell for the company.” – Mark TwainComment
Glad to see you took my advice...these are the best bang for the buck...In case you're scratching your head...I'm that xsroadrunner guy...LOL...cant wait to see the night shots...install looks like it was a piece of cake...I will take some, promise. It turned suddenly cold here so I'm waiting for the Indian summer effect.
2005 Honda SilverWing 600
2018 Honda PC-Xpress 150Comment
Running wiring on our old bikes is always a little tricky. Had to raise the tank to get underneath, etc.
The strange part was that white is hot, black is neutral. My friend Dan and I wired it the other way around ... and nothing. Then I finally got the idea to switch the wires, in case white was hot, and voila.
I drilled a hole in the nameplate for the switch, which you can barely see, and for simplicity's sake, we ran it directly to power - independent of the key or headlight. You can turn them on when the bike is off.
They're awesome, elegant and remarkably low power. Thanks again for the suggestion.1982 XJ1100J Maxim
2000 BMW R1200C
Black is always the neutral/ground in DC electrical. It's the international standard and has been for as long as I've been into electronics (since like junior high). A hot lead can be ANY color since you tend to want to have all the different circuits be different colors, but all the grounds can and should pretty much be the same.Cy
My friend Dan is the more experienced of the two of us, having rebuilt multiple bikes, but he's a contractor rather than a mechanic and must have been using AC logic. Now we know.1982 XJ1100J Maxim
2000 BMW R1200C
Yep, AC and DC colors are completely different. Gets confusing for us guys who work primarily with one and then work with the other. I know it does with me when I work with AC circuits.Cy
I feel a little silly now since I wrote to John Sanders to tell him that the lights are great but he should include instructions so folks would know white is hot...1982 XJ1100J Maxim
2000 BMW R1200C
No, not really, because many people with no electrical experience at all would not know one way or the other. So he should include in the instructions which is which for those who don't know the conventions or come from and AC background.Cy
Um, you Did put a fuse in that line, didn't you?and for simplicity's sake, we ran it directly to power
The lights may only draw little current, but a short will draw the lot.79 SF Special W/ Stock all original motor @ 384,000klms
*"The Keg"- UC torana hubs, XS11 discs, Tokico 4 spot calipersComment
I'm glad it has worked out for you...these LED lights are an excellent option and their application seems to be universal. Now that I have a job again..I am going to put these on both of my bikes. Oh and nothing could be trickier than to have to wire up something on an ST1100...or any bike that has plastic body work...it makes our XS's and XJ's a piece of cake in comparison.Running wiring on our old bikes is always a little tricky. Had to raise the tank to get underneath, etc.
