So after I got the fuel overflow issue fixed I put it all together and I've only got one problem left. However, it's a bigger issue than I thought.
At idle with the breather hose off, I noticed there was a lot of smoke coming out of the hose and then I noticed oil weeping from the valve cover in numerous places. This is what first started all this many months ago when I blew out a cam plug. Haven't figured it out yet.
Could it be:
1. valve seals leaking by thus causing the pressure increase in the case.
2. Piston rings
3. Head gasket
I'm committed to fixing it, but I don't know where to go from here.
I'm trying to figure if a compression test would tell me something I don't already know. I guess it might tell me which cylinder is messing up, but where in the cylinder would my problem be?
A little back story. before all this started, I had the notorious vac advance broken wire issue and had to limp home on 2 cylinders and rode it real hard. Fixed the broken wire and had a pressure problem since.
thanks in advance.
Could it be:
2. Piston rings
3. Head gasket
thanks in advance.
Ex-wife got the air compressor
CZ
, they will (with a small deposit) let you borrow an air compressor!
