No Tach + Runs like Crap? WTF?
  • Lucien Harpress
    • May 2009
    • 213
    • Adrian, MI
    I'm a bit annoyed I'm having to ask this question, because it's the SAME ONE I asked nearly two years ago, when I got the bike, and I THOUGHT I had it fixed. Which it was, for nearly a year and a half.
    HOWEVER...
    I start up the old hoss today, and it doesn't sound healthy. Not revving up, nor warming up like it usually does. And when I crack the throttle? Like I'm missing cylinders- there's no "get up and go", just a bunch of popping and sputtering. The most telling thing, though, is the tach is dead. As in not moving. Again.
    Normally, I would just check the connections behind the fuse panel and be done with it. But the fact the motor isn't running that great either gets me to thinking it may be something more than that. Any clue what is going on?
    (Quick note: It SHOULDN'T be a regulator/rectifier issue. I JUST replaced it with a brand-spankin' new model from Geezer. Just so that's out there)
    Currently XS-less.
    If that connector is acting up, it could effect the bikes performance. Also, Geezer makes good products, but even his stuff could go bad.
    I would look at pickup coil wires also.
