It went clank
  • jdabreeze
    • Oct 2006
    • 13
    It went clank
    OK took my 80 xs11 out for a putt with the sidecar. Went to pull away from a light and heard what sounded like the center stand smacking the frame. Picked up my son and again starting from a stop "clank". "Me" this isn't good I hope we can get home. Started up a hill and "clank" chatter chatter....coast to a stop
    "well thats as far as we are going tonight." Got it loaded on a trailer and is home now. Wont be able to dig into it till monday at the earliest probably next sat or sun
    Question: what should I look at first, I am guessing middle drive or final drive leaning towards middle because of where the noise seamed to have come from. This doesn't quite come as a surprise as I do ride the bike hard even with the sidecar attached.
    Thanks for the help
    Steve
  • mack
    • 2411
    • Ontario, Canada
    Clank
    I'd start with the easy stuff first. Pull the rubber boot back and see if you've sheared off the bolts connecting the drive shaft/middle drive. Then diagnose from there. I take the motor stiff runs good.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • jdabreeze
      • Oct 2006
      • 13
      I'd start with the easy stuff first. Pull the rubber boot back and see if you've sheared off the bolts connecting the drive shaft/middle drive.Actually got that far no signs of damage so far but only pulled the boot back to see the mounting flange. Then diagnose from there. I take the motor stiff runs good. Yep
        I have heard the primary chain "snap" against the engine casing before. Do you think it was that? Well may not, if it chattered all the way to a stop...
        • mack
          • 2411
          • Ontario, Canada
          well
          if it was mine I'd put it up on the center stand, pull or tie the boot out of the way, start it, put in gear and let the clutch out slow and watch and listen. If the shaft isn't turning the wheel, it could be middle drive, "U" joint, or a shaft.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
            This sounds vaguely familiar to what happened to Jerry a few years ago. The splines on his driveshaft to Final Drive wore down from lack of effective lubrication. "Breeze", I haven't seen you post on here before, so I'm thinking you're fairly new to the site. I don't know how long you've had your bike, but the Zerk fitting at the FD does NOTHING! You have to take the FD unit off from the swingarm to inspect, and clean/regrease the splines, best time is during rear tire changes.
            But as others have stated, on the centerstand and verify whether the rear wheel can be turned by the engine/tranny. I know you were able to roll it onto the trailer, but that was perhaps in neutral..which is still a good sign for the middle drive. Good Luck!
            • Jerry
              XS & TRUE XJ GURU
              • 3023
              • Elma, IA.
              I was coming down an off ramp on my way home from the Olympia Rally. I was pulling my trailer, as I do to most rallies. Put the bike in 1st, let out the clutch, clank. Bike is dead in the water.
              After getting the rig home I pulled the final drive and removed the drive shaft. The splines n the shaft, where they go into the final drive, haqd become so worn the shaft was spinning inside the final drive.
              Got a replacement shaft and final drive from Trbig on this list, put everything back together using Honda's drive shaft lube, and was back in business.
              Full thread is http://www.xs11.com/forum/showthread...rn+drive+shaft
              As TopCat said, if you have not pulled your final and looked at / lubricated your drive shaft, i would check there first. The added load of a sidecar, combined with inadequate lubrication, may have ended up causing s situation similar to what I experienced.
              If that is the case, replacement / repair parts should be found be in the $50.00 range, my guess.
              Jerry Fields
              '82 XJ 'Sojourn'
              '06 Concours
              My Galleries Page.
              My Blog Page.
              • jdabreeze
                • Oct 2006
                • 13
                Well its apart and it looks just like Jerrys. Now a question about part #s from what I understand the first 3 numbers are first model number that part appeared on and the next 9 are the part number so if the second 9 numbers match exactly it is the same part. Reason I am asking is I found a XJ750 driveshaft and final drive and the yamaha site shows both are shaft #46172-00-00 and FD #46101-00-00.
                Thanks for all the help.
                  Uh, not exactly with the part numbers! The first three are the MODEL designator, as well as when it first appeared, but for that particular model. The last numbers are descriptive for the TYPE of part, but the first 3 are critical (usually) for matching to your specific model. So... one from an XJ750 won't necessarily fit just because it has the same last #'s!
                  We found that out with just the XS750/850FD and driveshaft swap vs. the OEM FD. There's a link(in the LINKS SECTION) to the Parts Finder and comparator on the UK site that will tell you what year/models share the same part as your model of XS11
                  With many of the folks that have done the 750 FD swap, you should be able to find some OEM shafts and FD's.
                  Good Luck!
                    If you are looking for a driveshaft, XS/XJ1100's only, nothing else is the same. Info taken from Boats.net
                    Description
                    --- SHAFT, DRIVE, SHAFT, DRIVE 1
                    This Yamaha 2H7-46172-00-00 SHAFT,DRIVE part is also used on these models and components:
                    1978 XS1100E FINAL DRIVE GEAR-DRIVE SHAFT
                    1979 XS1100F DRIVE SHAFT
                    1979 XS1100SF FINAL DRIVE GEAR-DRIVE SHAFT
                    1980 XS1100G DRIVE SHAFT
                    1980 XS1100LG DRIVE SHAFT
                    1980 XS1100SG DRIVE SHAFT
                    1981 XS1100H DRIVE SHAFT
                    1981 XS1100LH DRIVE SHAFT
                    1981 XS1100SH DRIVE SHAFT
                    1982 XJ1100J DRIVE SHAFT
                    • cywelchjr
                      XS-XJ Super Guru(Deceased)
                      • 4450
                      • Sacramento, CA
                      And unfortunately for you, when doing the swap, only the FD is swapped, the original drive shaft is typically used unless it's FUBAR, or unless like me your lucky enough to have an extra that can be modded ahead of time, but that didn't give me an extra, it just means I have the original to go back to without having to unmod the one I modified.
                      • jdabreeze
                        • Oct 2006
                        • 13
                        Thanks for the input about the part numbers. I have other projects that will keep me from getting further along with the repairs. I have gotten a couple of sources for a XS final drive lined up when I have the time.
                        Thanks to all for the help.
