The turn signals that came on this XJ11 were not stock. The work fine but don't look right. They're black plastic rectangles with a flexible arm that bolts to the headlight. They don't have the square section that fits into the square hole grommet although the flexible arm they do have is less likely to get damaged if bumped.
Late last year I bought a couple of the two piece turn signals I thought were for the front but today when I went to put them in I see they're actually rear turn signals with the 3 wires.
Other than having an electrical fixture for a tail bulb, is there any reason why I should not use these for the front turns? If I wire them correctly so the turn part is engaged, I would only use the one bulb on the bike for turn signals & the same spare would also be what's needed for the rear tail light. That would be convenient...
Always something interesting...
Getting closer...
Getting closer...
