Lots of different brands out there. Which ones do you use or recommend?
Cruise Control
vista
its friction but its old and only holds for a bit - long enough to wave right hand or adjust something...
johnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
Had one, but I never used it much, mostly for just warming the bike up. They only work semi-well on flat roads; get any up-and-down going on, and they're pretty much useless IMO...
A better choice may be a 'throttle boss' or something similar; these do help reduce hand/wrist fatigue.Fast, Cheap, Reliable... Pick any two
I have the cheap 10.00 cruise. Works great on the freeway.
I also had the 10.00 throttle rocket knock off I bought at the dragon a couple of months back... in theory it would work but with my silicone grips it just ripped the grip glue loose and would slip like a biatch! I took it off and reglued my grip. Needs to be rougher inside or something. It seems to pinch the grip and pull it away from the throttle sleeve." She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. "
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
mikes650 front fender
led's gallore...
renthal bars
gold valve emulators
vmax tensioner
Rifle fairing
Originally posted by Nubian View PostI am talking about a true cruise control. Not a throttle lock.
I have both the Vista and the throttle boss, and I really like the Vista. Once adjusted right, it holds nicely, yet still allows you to adjust the throttle manually while locked. I did have to sand down the "detent" surface to get it to hold the lock though.1980 XS850SG - Sold
Ah, that's a different deal. But C'bug is right, the XS just isn't set up for a full-blown cruise control. I've looked at them several times, and the degree of difficulty installing one far exceeded the value for me. There's three major problems 'adapting' one that I see; one, most of them are designed to use the factory 'electronic' speedo for input (not a mechanical unit like the XS), two, you'll need custom throttle cables, and three, where to mount the servo? There's work-arounds for all this, but none will be particularly cheap or easy.
Mounting the servo would be the biggy IMO; if you're running a fairing, you could probably hide it in there, but if not there's just no place to hide it on a XS.Fast, Cheap, Reliable... Pick any two
I don't believe this is true - I've got a early 70's car that has a cruise control on it, and trust me when I say it doesn't have any sort of computer or fancy electronics on it at all. Not sure how it works, but it does.
Originally posted by CatatonicBug View PostOur bikes don't have the circuitry to handle a REAL cruise control. That requires computerized speed sensors and throttle adjustment servos. Unless you are an electronics guru, you're stuck with a throttle lock.
I have both the Vista and the throttle boss, and I really like the Vista. Once adjusted right, it holds nicely, yet still allows you to adjust the throttle manually while locked. I did have to sand down the "detent" surface to get it to hold the lock though.1979 xs1100 Special -
Originally posted by fredintoonGoes like a train, corners like a cow, shifts like a Russian tractor, drinks like a fish, you are gonna love it.
[link is broken]
Originally posted by psycoreefer View PostI don't believe this is true - I've got a early 70's car that has a cruise control on it, and trust me when I say it doesn't have any sort of computer or fancy electronics on it at all. Not sure how it works, but it does.1980 XS850SG - Sold
Cruise Control
I thought about this once or twice, you could probably use a micro programable logic controller with PID (proportional,intergral & derivitive) control and drive a servo with an analog output but this would take electrical power to work.. That's one thing the XS lacks! I agree with the others in saying it would not be economically feasible to do not to mention the space needed. My $0.02
Dale78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
2006 Roadstar Warrior
I'm not saying it can't be done, just that the degree of difficulty is fairly high...Last edited by crazy steve; 07-29-2011, 09:34 AM.Fast, Cheap, Reliable... Pick any two
I did a google search and found this place,
http://www.mccruise.com/Choose-Your-...le-Cruise.html
they've got a universal unit that comes with a speed sensor.1979 xs1100 Special -
[link is broken]
I'm agin' 'em.
Originally posted by Nubian View PostLots of different brands out there. Which ones do you use or recommend?
even if you can find a true cruise control for your bike I wouldn't recommend having one.
Cruise control (and a windshield and air conditioning and surround sound) are great for driving the family Buick but bikes is different and don't need none of that stuff.Fred Hill, S'toon
I have both the Vista and the throttle boss, and I really like the Vista. Once adjusted right, it holds nicely, yet still allows you to adjust the throttle manually while locked. I did have to sand down the "detent" surface to get it to hold the lock though.Cy
Originally posted by crazy steve View PostNo, the older units didn't require much in the way of existing electronics on the vehicle to work. Your car probably has a speed sensor installed in the speedo cable if its OEM, unless it's one of the aftermarket units that counted engine rpm, but the latter type weren't very good at maintaining speed due to slippage in the torque convertor with an automatic and tended to be a bit 'jerky' with a manual trans. You still have a 'computer' in there someplace that counts input signals to determine servo movement. It may be possible to use the existing speedo-mounted reed switch for the turn signals for input to a cruise unit, maybe not.
IIRC from just having reviewed the thread over on .org, it's about $200 for the kit.Cy
