ANYBODY NEAR NORTHEAST IL w/SYNC +/- COLORTUNE
  • ANYBODY NEAR NORTHEAST IL w/SYNC +/- COLORTUNE
    im financially unable to buy the nec tools to finalize my 81 Specials carbs. runs pretty good, but needs a sync and a/f mix adjustment. it would be great if anybody is close to Northeast Illinois near the Wisconsin border. need my Black Beast to purrr!
    Max
    81 XS1100SH Black Beast Mutt
    Kerker 4/1
    stock carbs and air box.
    78 headlite, handle bars,
    1 set of ea-160/85mph guages,
    crash bars, cruise control
    Other 2 Wheelers
    78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
    94 CBR1000F jet kit,Two Bros pipe, K&N Filter
    You ARE fantastically able to buy the tools to finish your carbs. You can build a sync tool for under $10 as good or better than any brand name tool. You need a good bit of vinyl tubing (cents per foot), 1 foot of vacuum line, little plastic barbed connectors (to go from vac line to tubing), and 3 plastic barbed T's to bring all 4 tubes together. There are TONS of write-ups on this subject so check out the search button and the tech tips and if you still can't find the needed info, I will post a pic of my own. Oh, and forget the colortune, it's expensive garbage. If you really want to get the best idle mixtures, get a vacuum gauge on the vacuum port and tune for the highest possible vacuum at a set RPM. If you want perfection alternate and repeat between setting idle mixture and syncing the carbs (which is exactly what you would need to do if someone was there to loan you a Motion Pro sync and a Colortune).
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
