lack of vacuum
  • Spootinay
    • Jul 2011
    • 62
    • NE FL
    lack of vacuum
    I removed the carb and placed the palm of my hand over each carb boot and turned the engine over one at a time. #3 carb boot had noticeably less suction than 1 2 & 4. On one two and four my hand was suctioned on to the boots whereas on number three my hand wasn't suctioned to the boot.
    What does this mean? Do I have a hole in the piston or what?
  • Stepka
    • Apr 2011
    • 170
    • Shakopee, MN
    I had kinda the same problem and it was that the valves were to tight
    1981 xs1100 venturer... Finally runs
    Still has carb issues, but runs
    For all of your Amsoil needs go to www.mrguysoil.com
      Do a compression check. Is the same cylinder low?
        Aside from the valve lash/clearance possiby being too tight, you may also have a vacuum leak in the boot itself, or where it mates to the engine, as well as the SYNCH PORT...that cap can dry, harden, and leak also! As stated, check the compression if you have a gauge, if not, then check your valve clearance...you should have/own a feeler gauge.
        • Stepka
          • Apr 2011
          • 170
          • Shakopee, MN
          Easy way to see if it is a boot or hose, is to spray carb cleaner or starting fluid on the item you suspect.
          • cywelchjr
            XS-XJ Super Guru(Deceased)
            • 4450
            • Sacramento, CA
            The carb cleaner trick only works if you have a running engine. If your doing checking before you even try to start it, that trick isn't going to work. That said, as compression check will tell you if it's valves or not real quick thought, cause if the compression is good and the valve clearance is good then it's not valves and you can start looking at the intake track for a leak.
            • planedick
              • Mar 2005
              • 2068
              • Yorba Linda, California
              Compression check
              Do a compression test dry then again with a little oil in the cylinder. This will tell you if it might be bad or broken rings. A better (higher) reading after the oil will help seal bad rings and make a higher reading if the rings are bad.
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
              Custom security system
              Stainless braid brake lines
